Audio Cutting Out at High Volume after Putting in New Speakers
Okay so I bought some new speakers from Amazon for my 98 Jeep Cherokee. They are Rockford Fosgate R1525X2's and I put them in the rear and connected with some connectors I got from crutchfield. I have stock speakers in the front doors and an old JVC KD-G510 head unit. When I have the volume on my iPod up pretty good and the volume on the head unit from 33 or so to 40+(maxes at 50) the sound cuts out when the bass is hitting. If I have the volume at 30 and my iPod all the way up everything seems to run smoothly. Do I need aftermarket speakers for the front doors as well, maybe a new HU?
I got back in the jeep later, and it seems to have gone away I didn't make it as loud, but I was playing around 35 without any cutting out with the jeep running, I didn't try it not running.
Are you running STOCK/OEM head unit?
Are the NEW speakers the SAME impedance (ohms) as OEM?
EDIT: Nevermind, ... I NEED to read BETTER. I am a dunce.
Zeke
'14
2003 Chevy Monte Carlo SS
Vehicle Details & Mod List: http://www.stevemeadedesigns.com/board/garage/vehicle/1703-chevrolet-monte-carlo-ss/
Audio Build Log: http://www.stevemeadedesigns.com/board/topic/143276-2003-chevy-monte-carlo-ss-audio-build-ib-build
Pioneer FH-P8000BT
Infinity Kappa Perfect 6.1
Fi IB3 (Two 12", 2-ohm SVC)
RF T400-2 & T500-1bdCP
MechMan S Series 240A
XS Power D3400 & D975
Could his deck be getting hot pushing 4-ohm into OEM front door speakers that are likely 2-ohm, while running the RF's at 4-ohm in the back? Clipping itself when needing to draw power?
Plus, keep the volume down a tad from full-tilt on your iPod, etc. ... Along the lines of a gain control that you do not want cranked all the way up. Let the lower volume & headunit do the work for you ... if not loud enough, then time to step up to external amps, etc. Or maybe a higher wattage headunit.
Zeke
'14
Pioneer FH-P8000BT
A guy from crutchfield had some crutchfield research stuff on the Cherokee and he said the stock speakers are 4 ohm, I don't get any cut out while driving so far, only while sitting off, and sometimes sitting running. But it didn't happen the last time I was listening. Maybe it's time I upgrade the old jvc to a pioneer I'm looking at.
Uh, erm ... Uh, OK. Loose connections?
I do not know, ... I give! "Uncle!"
Zeke
'14
Pioneer FH-P8000BT
Checked the connections and they seem to be good and don't come loose as far as I can tell. Like I said they are stock adapters for the speakers they click into the jeeps connector and slide onto the speaker posts.
I am talking about the connections behind the JVC H/U ....
Zeke
'14
Pioneer FH-P8000BT
Oh I haven't looked at that, but like I said it doesn't cut if I fade it to front or rear. And also it doesn't cut if I were to put stock rear speakers back in, the change happened when I put the new speakers in.
  • Who's Online   0 Members, 0 Anonymous, 1031 Guests (See full list)
