Sound Deadening Solutions - Advice, Tips etc...
Jamie Bakaj
Hey everyone, long time fan (of Steve and his Tahoe) and the car audio scene, now first time poster!
Just wondering if anybody could give some advice on sound deadening products such as Second Skin, Stinger RoadKill etc, through to spray/paint-on products like Motorspray Sound Deadener.
I'm planning on matting my front doors with either Dynamat or Road Kill today, but was wondering if adding some spray-on or paint-on deadener was worth doing for places I might not be able to get to (should that be the case) or even applying it over the matting for "added effectiveness"
K thanx GO!!
1999 Mitsubishi Verada/Diamante Wagon A.K.A The Bassubishi.
-Fusion CA-CD800 HU
-Soundstream MPQ-7XO Eq. (Only hooked up to the fronts)
-4x Soundstream PC.6 Front Stage (2 installed, 2 more on the way)
-2x Soundstream SF.693T Rears (yet to be installed)-1x Cadence 2 channel amp (FX102/302???)
-2x Fusion FPW1200's
-1x Fusion PP-SW150
-1x Fusion PP-AM300010
-1x Soundstream DTR1.900
-Custom 240A Excessive Amperage Alternator
-1x Optima D34 Yellow Top
-2 Gauge power cabling.
-A few gauges (4 in total) including voltmeter.
-Some carbon fiber wrapped bits.
-1x Nice sounding daily driver!!
if you get a quality deadner such as second skin audio techixs you will not need to cover 100% or cover with a spray on deadner to achieve good results !! spray on deadner while it works i have not been a fan of due to it works more as a mass loader because it does not have a constraining layer.
Thanks for that!
I'm considering getting Second Skin if I can find a distributor here in Australia, otherwise I might just get Dynamat or Stinger Roadkill from somewhere local.
-Fusion CA-CD800 HU
-1x Fusion PP-SW150
both are good product ... just make sure you get a product with a good foil backing ( not just like aluminum foil but can actually bend and hold its shape because of the foil backing) and dutyl rubber based and you should be good to go!
  • Who's Online   0 Members, 0 Anonymous, 1541 Guests (See full list)
