sbg Posted July 24, 2013 Report Posted July 24, 2013 I just got a JL 1200.1 cheap off a guy, so I take out my VVME 1000.1 and put the JL 1200.1 in. thing is now with the JL I have to turn my volume on my head unit( jvc k-ds37) way to high for the bass to start hitting hard. before with my vvme I only had to turn my volume to 18 out of 50 for it to be loud and sound good. now I have to turn my head unit up to 37 out of 50 for the bass to be loud but at that volume my door speakers are about to die! I don't have a dd1 so I set the JL up to what the manual said to to. not sure on what to do now lol.. I don't know if its head unit or amp problem. this is what the amps manual has in it so this is what I did. Input Sensitivity Level Setting Following the directions below will allow the installer to adjust the input sensitivity of each amplifier channel pair simply and easily in just a few minutes using equipment which is commonly available in installation bays. Necessary Equipment • Digital AC Voltmeter • CD with a sine-wave test tone recorded at 0 dB reference level in the frequency range to be amplified for that set of channels (50 Hz for subwoofer channels, 1 kHz for a midrange application). Do not use attenuated test tones (-10 dB, -20 dB, etc.). The Nine-Step Procedure 1) Disconnect the speaker(s) from the amplifier’s speaker output connectors. 2) Turn off all processing (bass/treble, loudness, EQ, etc.) on the source unit, processors (if used) and amplifier. Set fader control to center position and subwoofer level control to 3/4 of maximum (if used to feed the G-MAX). 3) Switch the “Input Voltage” switch to “Low” and turn the “Input Sens.” control all the way down. 4) Set the source unit volume to 3/4 of full volume. This will allow for reasonable gain overlap with moderate clipping at full volume. 5) Using the chart on this page, determine the target voltage for input sensitivity adjustment according to the nominal impedance of the speaker system connected to the amplifier outputs. 6) Verify that you have disconnected the speakers before proceeding. Play a track with an appropriate sine wave (within the frequency range to be amplified by the G-MAX) at 3/4 source unit volume. 7) Connect the AC voltmeter to the speaker output connectors of the amplifier. Make sure you test the voltage at the correct connectors (+ and –). 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
pioneerforlife Posted July 24, 2013 Report Posted July 24, 2013 my guess is that either the gain is too low or you have the subs wired to a higher impedance. what do you have your subs wired too? 2007 Ford Focus SES Hatchback Pioneer HU 4 Digital Designs 9515i's in a B pillar. 2 Soundstream XXX 15K's (running at 16 volts) Soundstream Mids/Highs in custom door panels (getting rebuilt soon) Soundstream TA2.160 and TA2.400 Sky High and KNU wiring 3 Banks of Maxwell caps Winston Lithium (not a fan) Bump4Life 250 Amp Alt. aka USAlternators Soundstream Focus and Avenger Build Log Instagram @p4linnovation YouTube: Team Blowin Loud
sbg Posted July 24, 2013 Author Report Posted July 24, 2013 my guess is that either the gain is too low or you have the subs wired to a higher impedance. what do you have your subs wired too? 1 ohm , and I set my gain to 49v like the amp manual said to. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
pioneerforlife Posted July 24, 2013 Report Posted July 24, 2013 my guess is that either the gain is too low or you have the subs wired to a higher impedance. what do you have your subs wired too? 1 ohm , and I set my gain to 49v like the amp manual said to i think i now your problem. you set your gain at 3/4 of your volume on your head unit. they say 3/4 of volume because generally that is the maximum un-distorted volume. therefore, your subs will only be at full volume at 3/4 volume. re-set your gain at the volume the subs used to be very loud at (18) and that should solve your problems. 2007 Ford Focus SES Hatchback Pioneer HU 4 Digital Designs 9515i's in a B pillar. 2 Soundstream XXX 15K's (running at 16 volts) Soundstream Mids/Highs in custom door panels (getting rebuilt soon) Soundstream TA2.160 and TA2.400 Sky High and KNU wiring 3 Banks of Maxwell caps Winston Lithium (not a fan) Bump4Life 250 Amp Alt. aka USAlternators Soundstream Focus and Avenger Build Log Instagram @p4linnovation YouTube: Team Blowin Loud
