Charging voltage seems low. Summer?
Normally I charge at 14.5 hot, and 14.7 cold. But recently here in Texas summer (my first one) my alternator is charging at 14.5 start and its not charging amazingly. Ill get 14.2 at the with the system off... And when I'm playing with a fully charged battery, ill drop to 12.8 (not the 12.0 from a couple days ago, uncharged batteries) but it takes a lot longer then normal to get back up to full voltage. Like almost 40 seconds, instead of normally 15 seconds.
Is this just summer / heat being a bitch?
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Guest DC Power Kyle
Normal. When it's hot outside there is a larger amount of temperature compensation. Depending on what vehicle make you have there are different set points.
  • Who's Online   0 Members, 0 Anonymous, 627 Guests (See full list)
