Xplay75 Posted July 27, 2013 Report Share Posted July 27, 2013 I just picked up a pair for $50 from a pawn shop,they are dule vc 600 watts a piece,I have 2 amps witch I can run them on but need advice,one is a jl 500.1 and the other is a rf 1500 bdcp,any ideas witch one to run,Idk if u can over power them,had it hooked up to the jl and when turned up loud one would make a slight popping sound but went away when I covered the port a little with my hand,Idk if I have to change the crossover to void out that frequency or maby the box is to small,its a prefab box,any ideas would b help full Link to comment Share on other sites More sharing options...
Xplay75 Posted July 27, 2013 Author Report Share Posted July 27, 2013 Ok fixed the popping,the low pass cover was set to high,any ideas on witch of my amps to run? Link to comment Share on other sites More sharing options...
Guest Posted July 27, 2013 Report Share Posted July 27, 2013 low pass prevents high notes from being played. subsonic prevents low notes from being played. considering those are 400rms a piece, i would probably run the fosgate amp with the gains set VERY conservatively. that amp has the ability to throw twice the rated power of the woofers. Link to comment Share on other sites More sharing options...
Xplay75 Posted July 28, 2013 Author Report Share Posted July 28, 2013 Does any one know what the max air space specs for these 12s are,went to the website and it dosent have any on it?,unless I'm blind lol Link to comment Share on other sites More sharing options...
Xplay75 Posted July 28, 2013 Author Report Share Posted July 28, 2013 thanks for the advice,I know that the rf could kill thoes subs easy,any advice on setting that gain so I don't kill it,I don't have any type of meter low pass prevents high notes from being played. subsonic prevents low notes from being played. considering those are 400rms a piece, i would probably run the fosgate amp with the gains set VERY conservatively. that amp has the ability to throw twice the rated power of the woofers. Link to comment Share on other sites More sharing options...
