1997 ford explorer remote start install
I have 97 explorer trying to figure out how to install viper 5901 remote start. I tried and I could not figure it out. Has anyone done this install? Which color wires go to the truck. The easy way to get this going. Thank you
Constant 12V+ Yellow Ignition Switch Harness Starter Red/Light Blue Ignition Switch Harness Ignition Light Green/Purple Ignition Switch Harness Ignition 2 Black/Green Ignition Switch Harness Accessory Gray/Yellow Ignition Switch Harness 2 Wires (Heat/AC) Tach Tan/Yellow Pin 48 at PCM Passenger's Rear QTR Panel Neutral Safety Wire Not Grounding OEM Switch opens Starter Circuit Brake Switch Light Green Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights White/Black (+) Switch (Brown at Firewall ) Head Lamp Red/Yellow (+) Light Switch Factory Disarm Dark Green/Purple (-) Driver's Kick Panel Door Trigger Black/Light Blue Driver's Kick Panel or Light Switch Door Lock Pink/Yellow (-) Driver's Kick Panel Door Unlock Pink/Green (-)
"crank it til it hertz"
Constant 12V+ Yellow Ignition Switch Harness (2 Wires) Starteraa Red/Light Blue Ignition Switch Harness Ignition Light Green/Purple Ignition Switch Harness Ignition 2 Black/Green Ignition Switch Harness Accessory Gray/Yellow Ignition Switch Harness 2 Wires (Heat/AC) Tach Tan/Yellow Pin 48 at PCM Passenger's Rear QTR Panel Neutral Safety Wire Not Grounding OEM Switch opens Starter Circuit Brake Switch Light Green Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights White/Black (+) Switch (Brown at Firewall ) Head Lamp Red/Yellow (+) Light Switch Factory Disarm Dark Green/Purple (-) Driver's Kick Panel Door Trigger Black/Light Blue Driver's Kick Panel or Light Switch Door Lock Pink/Yellow (-) Driver's Kick Panel Door Unlock Pink/Green (-)
