2009 Camry Se rebuild. Sub stage finished.
Yea I took it out a while ago when running wire and just never put it back in ......and no, sadly my seats don't fold down..... I just leave them unbolted and when I want some cleaner bass I just lay them down
Kenwood Excelon x396AQ2200Fi Q 12XS D3400
XS XP30001/0 RADAFLEXStinger volt meter
Mechman 240a alt
Just used up my last stereo warning. Motorcycle cop got me on the way home didnt see him in time because I was coming up a hill. Didnt help that my windows were down and no traffic......
Mechman 240a alt
  • 3 months later...
ah the camry se. gotta love that rear brace.. mine is a 07 se running 2 idmax 12s- have you ever thought about building a box where the port of the box fires through the armrest fold down that opens through the back seat? assuming seal off the trunk. does that theory work? :(
I see Booty
2007 Toyota Camry
19" VMR Rims
H&R Lowering Springs.
Magnaflow Exhaust System
K&N Air Intake
6k HID Projectors & Fogs w/ Black housed headlights.
Optima Yellow Top - Front. Kinetik HC 600 - Trunk
Kenwood KVT-617
Rockford Fosgate 3sixty.2
Rockford Fosgate T2001-BD - Sub Amp
Alpine MRV F-345 - Front stage
Front Stage - A pillars - Dayton Audio 4" mids w/ Vifa Tweeters
Front Doors - Vifa - 6.5" midbass 1" Vifa Tweeters
Subwoofers - 2x 12" Image Dynamics IDMAX - 2.91 cuft ported enclosure tuned at 25hz
I had an idea a while back of using 2 8s in a 4th firing through the armrest, but you would need to seal the trunk off, even the rear deck which is a major pain to get to. I think if done properly it wouldnt be a bad idea
1898070_635754349830843_1457278514_n_zps
I agree - i have rear fill 6x9s which i do not plan on using. i think i will attempt to seal off the trunk + rear deck and have a port firing through the rear arm rest. Ironically i have a old box that i built for my idmax's - the port is small and in the middle and aligns perfectly with the opening.
The question is do I extend the port a bit outwards and make it "part" of the cut out in the arm rest. or do i just seal off the trunk and leave a gap between the armrest opening and the port? Thanks for the insight.
Your build is amazing!
I see Booty
2007 Toyota Camry
19" VMR Rims
K&N Air Intake
Kenwood KVT-617
