2009 Camry Se rebuild. Sub stage finished.
Just ordered this to keep my 3400 nice and refreshed......and a 40$ router bit to cut holes........damn routers.
Kenwood Excelon x396AQ2200Fi Q 12XS D3400
XS XP30001/0 RADAFLEXStinger volt meter
Mechman 240a alt
Used some left over wood from the box to make a small false floor. Current box doesn't have a ghetto lean anymore.
2FA3892D-EECB-4E77-9810-FD28715B7AD1-199
Mechman 240a alt
Anyone have any ideas for an amp rack in the trunk. Right now it's on the top back of the trunk, and I know it doesn't look like it but its really sturdy and functional. If I get a flat all I have to worry about is taking out the speaker wire and pulling the box. And no the tape is not because there was a tear in the wire or anything. All I had at the time to label the power wire.
B07A0993-1F91-4BF1-B4A5-500EEA996CA1-199
Mechman 240a alt
Actually, disregard the above charger, went ahead and got the next size up. Hopefully this can bring my battery's resting voltage back up.
Mechman 240a alt
Yea, how do you like these clamps?? Holds the "45s" and gets the job done.
658B9116-76D7-4879-BE12-6FEC59199A08-212
Mechman 240a alt
On my 97 camry LE, i grounded the front battery to both the engine and frame using the factory grounding locations (i pulled the stock 8guage out and replaced with new 4awg)
On my camry their is a nice location directly under the battery mounting location, 4awg works great there :) your strut tower ground should be plenty long enough to reach either location :P
Regardless, props for at least using quality wiring!
Yea I tried that spot but I couldn't get the 1/0 to it.
Mechman 240a alt
Sanding and resin starts tomorrow...
479AE923-9418-4D94-8C2E-46C2CF2E9F32-215
Mechman 240a alt
This is the color I decided on
7471B112-955B-4734-B6BB-F24BEE674629-220
Mechman 240a alt
