SnowDrifter Posted August 5, 2013 Report Share Posted August 5, 2013 Any belt residue on the alt? Black powder? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
MonkeyMan Posted August 5, 2013 Author Report Share Posted August 5, 2013 Any belt residue on the alt? Black powder? Its only been on the car for about 30 minutes of driving, and only been loaded for about 3 seconds, so, no Link to comment Share on other sites More sharing options...
MonkeyMan Posted August 5, 2013 Author Report Share Posted August 5, 2013 I haven't actually been able to find any specs as to what voltage the alternator is meant to do... :/ Link to comment Share on other sites More sharing options...
SnowDrifter Posted August 5, 2013 Report Share Posted August 5, 2013 Usually 14.6ish iirc What's your pulley size and idle speed? And what size alt did you get? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
MonkeyMan Posted August 5, 2013 Author Report Share Posted August 5, 2013 14.6v hot, or cold? 320amp universal. crank is ~6.5inch, although idle is lower, at about 600rpm. Link to comment Share on other sites More sharing options...
MonkeyMan Posted August 5, 2013 Author Report Share Posted August 5, 2013 Did a test, ~200amp load on the battery and alternator, dropped to 11.6volts on a 3 second burp :/ well, I guess when the alt is only doing 80amps, it won't help much. Could just be that the revs aren't high enough.... I've ordered a shorter belt, see what happens I guess. edit: it idles too low to get any decent current at idle, I tested again at 2000rpm, and got 280amps at 13.8volts (the entire amplifier and cars current draw I'd say) but to me, this suggest the belt can't be slipping much, if at all :/ Link to comment Share on other sites More sharing options...
Miguels Posted August 5, 2013 Report Share Posted August 5, 2013 my alt is exactly the same. its the 320a model and i have the same issue.. it was sent to be repaired i just never went through the trouble of putting it back in my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
MonkeyMan Posted August 5, 2013 Author Report Share Posted August 5, 2013 my alt is exactly the same. its the 320a model and i have the same issue.. it was sent to be repaired i just never went through the trouble of putting it back in hang on, so are you now saying that it was faulty? :/ Link to comment Share on other sites More sharing options...
Miguels Posted August 5, 2013 Report Share Posted August 5, 2013 it blew a bearing.. though i know it was slipping since it got black all around the alp pulley i was told by Eric it was slipping after i showed him video my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
MonkeyMan Posted August 5, 2013 Author Report Share Posted August 5, 2013 Bearings normally fail if the belt is too tight Link to comment Share on other sites More sharing options...
