Alpine SWR-12D4 enclosure help
Hello !
I have just bought single Alpine SWR-12D4 sub with Alpine PDX-M6 amp...
And here is the problem - I've already tried different types of calculators, such as Torres old and new version, WinISD, BassBox 6 Pro, RE Audio calculator, to design proper enclosure. But every time I get different results... :(
And there is another problem. Recommended enclosure size Alpine has given for this sub in Product catalogue 2013 - 2014 and sub's user manual are different. So I am a bit confused which data must be used to make proper enclosure. For example - in users manual recommended volume range is 1,0 - 1,5 ft3 but in product catalogue recommended vented box volume is 53,8 liters ~ 1,9 ft3...
So I thought maybe you could help me with this enclosure. I would be very thankful if someone could design L-type vented enclosure for my sub... :blush: It is a lot easier for you to do that because you have already designed many enclosures... :)
Available max dimensions - H = 17; W = 25; D = 17.
Tuning 32 - 34 Hz
It will be used in VW Golf MK4
Thank you.
P.S. - I am sorry for grammatical mistakes. English is not my native language so I hope you understood everything I wanted to tell you... :)
That catalog if I am not mistaken lists the SWR-1243 ( 4th generation ) instead of the SWR-12D4 ( 5th generation ) that you have, therefore it's 1.5 cubic feet net.
Anyways, in the following situation Torres is accurate:
Dismiss bracing.
Port parts as follows:
Top to Bottom: 10 3/4" x 12 1/2"
Extension: 18" x 12 1/2"
iv got the same sub with basically the same box you need a bigger port , iv got 2 inch by 11.5 and its to small , i get a bit of port noise not bad but a little
my box is tuned 2 , 29hz and is 28 inches/16/13 with a 2 inch port
if i was to do it again id do a 3 inch port, mines a single baffle it seems to hold together fine ,im
running 800-1000w rms ,nice and loud, better lows than a sealed box not bad for a single 12
Dismiss bracing.
Thanks for design...
I thought I could make an experiment and I dropped your dimensions in torres on my computer...
Here is what I got -
Old version:
New version:
Do you think that extra baffle is necessary???
The double baffle is not strictly necessary but recommended, I would do the bracing at least. Subsonic filter to 28Hz, you are only running 600W on a 1K sub, there should be no issues, check your electrical and set your gains properly just in case.
Really weird what the calculator is doing in your computer, in any case I know the above is correct as I have double checked it by other means.
Edit: try a .net framework reinstall.
  • 3 weeks later...
  • Who's Online   0 Members, 0 Anonymous, 847 Guests (See full list)
