vanno79 Posted August 8, 2013 Report Share Posted August 8, 2013 which brand do you recommend crossover Link to comment Share on other sites More sharing options...
primer Posted August 8, 2013 Report Share Posted August 8, 2013 I'll probably get burned on the stake for this, but I use autotek. I have 2 in my truck and haven't had a single issue with either of them. I'm sure there are better or some that have more extra's. But for the money they work great. Depends on how much money you want to spend. Autotek: http://www.amazon.com/Autotek-ATK2-Crossover-Hideaway-Active/dp/B00CCILR0A/ref=sr_1_3?ie=UTF8&qid=1375999391&sr=8-3&keywords=autotek+crossover Clarion: http://www.amazon.com/Clarion-MCD360-Way-Crossover/dp/B00069R0LM/ref=sr_1_1?ie=UTF8&qid=1375999474&sr=8-1&keywords=clarion+crossover Planet audio: http://www.amazon.com/Planet-Audio-EC10B-Electronic-Crossover/dp/B002QUZHXW/ref=sr_1_1?s=automotive&ie=UTF8&qid=1375999627&sr=1-1&keywords=planet+audio+crossover Rockford Fosgate Processor: http://www.amazon.com/Rockford-Fosgate-Processor-Integration-Capabilities/dp/B004V9GSTS/ref=sr_1_1?s=automotive&ie=UTF8&qid=1375999704&sr=1-1&keywords=rockford+fosgate+3sixty.3 Also, look through this site. I'm sure that there are some supporting vendors that have a product that fits your needs. Take what you are doing into account. Figure out what you are doing with your system and look for the product that fits your needs. I'm running 12 channels so I have 2 crossovers. How many channels are you planning on running? Are you looking for SQ or just bass? Does your head unit have an eq? How many amps? These are all questions to take into account when buying additional equipment. 2002 GMC 2500HD w/8.1 liter v-8 Pioneer Avic N-5 HU Pioneer CD-BTB200 Bluetooth Pioneer CD-UB100 usb Pioneer GEX-P910XM XM receiver Pioneer CD-1200 IPhone adapter Pioneer TS-W309D2 subs x2 Audiopipe split 3003 2 Autotek 3-way active crossovers 2 alpine tweeters RF Punch P132 3.5" full range RF Power T1462 4x6 full range RF Power T1693 6x9 3 way RF Power T2652 T2 6.5 components 2 Autotek ATX 1200.4 amps 4 RF P400 amp Massive N4 nano-block I measure loud by the amount of smoke it puts out. www.enforcer-gaming.com Link to comment Share on other sites More sharing options...
vanno79 Posted August 9, 2013 Author Report Share Posted August 9, 2013 Pioneer - 6.1 "- CD / DVD - Built-In Bluetooth - Built-In HD Radio - In-Dash Receiver BRZ2100.1D Hifonics Brutus D-Class Mono Block 1 x 700 @ 4 OHMS, 1 x 1400 @ 2 OHMS, 1 x 2100 @ 1 OHM by Hifonics 2 woofer kicker cvr 12 Kenwood Excelon X700-5 5-channel Amplifier interferes 4 ch amp 4 Rockford Fosgate Watt PPS8-6200 6.5 "Single 8 Ohm Mid-Bass Range PAIR PIONEER TS-D6802R D-Series 6x8 "260W audiocontrol epicenter think you can help me designing my audio system including box for my woofer Link to comment Share on other sites More sharing options...
primer Posted August 9, 2013 Report Share Posted August 9, 2013 If I had experience with the equipment you are using, I would be happy to help you. But I have not used any of the equipment in your set up. I wouldn't feel comfortable advising you to do something unless I knew the effect it would have, because I am the type of person who would feel guilty if I told you to do something that damaged your system. What I do when I build a system is look up all the info for the equipment I'm using. A lot of the time I put it on paper. Draw a schematic for everything. How it's going to connect to everything. For instance, find the output voltage of your head unit. Write it down on the schematic. Find the input voltage range acceptable to the component it feeds in to. Do that for everything. If you get the output of one component close or matched to the next component, you are going in the right direction. Where are you located? 2002 GMC 2500HD w/8.1 liter v-8 Pioneer Avic N-5 HU Pioneer CD-BTB200 Bluetooth Pioneer CD-UB100 usb Pioneer GEX-P910XM XM receiver Pioneer CD-1200 IPhone adapter Pioneer TS-W309D2 subs x2 Audiopipe split 3003 2 Autotek 3-way active crossovers 2 alpine tweeters RF Punch P132 3.5" full range RF Power T1462 4x6 full range RF Power T1693 6x9 3 way RF Power T2652 T2 6.5 components 2 Autotek ATX 1200.4 amps 4 RF P400 amp Massive N4 nano-block I measure loud by the amount of smoke it puts out. www.enforcer-gaming.com Link to comment Share on other sites More sharing options...
SnowDrifter Posted August 9, 2013 Report Share Posted August 9, 2013 Before I suggest anything: What sort of functionality do you need? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
