jouniorlord Posted August 10, 2013 Report Posted August 10, 2013 Hey guys im about to upgrade my truck and im aiming to total ground pounder its gona be a Frankenstein setup so plz dont dis me for that lolz I would like some feed back what do all u vets think im really lookin for some advice this will be the biggest build ive ever atempted so heres the list of stuff I am getting 2x fi audio sp4 18d2s 1x lanzar opti 7000 1xjl audio jx360/4 5x everstrt marrine 122 ah batteries 1x mechman 250amp alternater All knukonceptz wire Crecendo cz series door speakers 1 x ssl 10 farad cap Okay so I know my batteries are not sealed but they wont be in the cab there gona be in the tool box and I know some one is gona wana say really ur using ever start but I used one in my last set up and it workeed great and they do hold alot of juice. Im gona be able to get apl this for $4k. Its gona be walled 13.8 cubes @32hz and its going in a chevy 1500 extended so what do u think any advice on the build or pointers I could really use the help im a little more then a lot overwhelmed buy all the work its gona take lolz...thanks guys
Watch the bass Posted August 10, 2013 Report Posted August 10, 2013 First Ditch the cap, cap´s are only usefull if you´r electrical system is a solid rock. And a 250 amp alt alone for this power is on the really small side. You need 100-120 amp for your car-electricity and have 130 for the audio. And you easyli will have a draw of a vew 100 amp´s from your audio. With only the one alt i wouldn´t do 0.5 Ohm system´s might be a better idea to snatch up the http://www.ebay.com/itm/New-OPTI6000D-Optidrive-Series-6000Watt-Mono-Block-Digital-Competition-Class-Amp-/330955077884?pt=Car_Amplifiers&hash=item4d0e75b8fc they does 6 K @ 1 Ohm. "in the abundance of water, the fool is thirsty" Bob Marley
jouniorlord Posted August 10, 2013 Author Report Posted August 10, 2013 OkAy so maby two 250 amp alternaters? Loose the cap and keep the 7k?
