I just upgraded my system from a class ab 4ch 160wrmsx2 and one 150wrms sub and one 250wrms sub to two brand new 250wrms subs and a d-class 4ch 440wrmsx2 @ 4 ohms bridged I also upgraded my wire from 8 to 4awg
But here's the problem. The subs won't crank out sound nearly as hard as the old gear. And when I get the gains near max the voice coils over heat and start to stink. Part numbers are fusion ca-da41400 and en-sw120(x2) kit is fusion 4ga (recommended with amp)
the subs are rated 150rms and how to you got it hook to the amp you have to bridge it on the fr+ fl- on one sub and the other sub to rr+ rl-
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
is the box different.
what else is different besides the wiring, woofers, and amp.
did any of the headunit settings change?
if you took the - terminal, off the battery, the headunit would have reset back to factory settings
i assume each sub is wired to 2 bridged channels of that 4 channel?
  • Who's Online   0 Members, 0 Anonymous, 483 Guests (See full list)
