On this subject I've had many long talks with fellow competitors (from european champions and down) and audio builders in other areas (both PA and home speakers).
Any build material has its advantages and disadvantages. MDF is only "dead" when it's in the appropriate thickness and braced accordingly. The same goes for basically any build material, like plywood, fiberglass (and other composites like carbon fiber), plastics (like acrylic/plexi) and metals like steel and aliminium.
A dead box is a dead box, regardless of build material. You have to adjust build method/thickness/bracing/damping accordingly though, to the build material of choice.
It's only when it's improperly built you can really hear differences. A thin/flexing MDF box and thin/flexing fiberglass box may colour the sound differently, but if both are solidly build and dead/free from vibration/resonance, they will sound the same (since they don't colour the sound).
In PA speakers, plywood/birch is favoured, since it's stronger than MDF, meaning you can use thinner walls for the same stiffness. Resulting in lighter speakers (meaningful when they are both lugged around and shipped).
So basically, a totally dead box will sound the same (or rather, not "sound" at all) from a variety of build materials. You just have to build it with regards to the properties of the material itself :)
Gotcha man, thanks for the response!
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
