Amp going into protect, then voltage surge? AGAIN! Dif amp?
Like a crackling noise...which makes me think that it's the speaker wiring? Hmmm
2007 Volvo S40 2.4i (no turbo :( )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
Okay i figured it out. I unhooked the speakers, that fixed the problem. Turns out only the LEFT channel works.. Essentially making it the same amount of wattage as the amp i had before.... I might go open it up in a minute and take pics.
I hooked up an old 4 ohm speaker up to the right channel and it fried instantley... Soni know its the right channel. Left works fine. Imma try to call the guy back and see if he will repay me my money so lets see what happens now...
And i tried also bridging it at 4 ohm... Protect
Also tried both 4 and 2 ohm on right channel only.. Protect.
Left channel, works flawlessly.
And i opened it up... Not even one black mark on the whole board... Looks brand new... So idk.
I just wasnt payig attention when he did that. He had his suhs wired to 2 ohm and only had one channel used anyways, BUT, he "says" he didnt install the system. Just another lessoned learned. Im not worried about it though i got my money back its all good.
Okay kyle...
So last night i was just jammin, and my sub cuts out.. i get out and try to hook up the connections all over again and boom... Terminal sparks and does the SAME EXACT THING as what happened with the other amp! WTF???
Compltely different amp... Does this mean my equipment is faulty or something that is causing it??
Okay now with all connections removed the amp keeps poppin fuses.. Wtf what in the hell could have caused this?
Anyone?
  • Who's Online   0 Members, 0 Anonymous, 600 Guests (See full list)
