Box designer get in here! Please
sbg
Need a box design please, tryed myself but couldn't get the port area I need. just not the best at design. Thanks
97 lumina trunk
4-12" re audio srx
1500 rms @ 1 ohm amp
Rap/decaf
Daily music box
14.5 "H
32 "w
35" D
Sub specs
Model SRX 12
Electrical Q Value -Qes 0.41
Mechanical Q Value -Qms 4.99
Total Speaker Q Value -Qts 0.38
Free Air Resonance -Fs 23.6 Hz
Equivalent Compliance -Vas 85 liters
One-Way, Linear Excursion -Xmax 18 mm
Efficiency -SPL 1W/1m 86.2 dB SPL
DC Resistance -Re 1.8 ohm
Nominal Impedance -dual 2 ohm
Thermal Power Handling-RMS 300
Force Factor -Bl 14.35
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
Would like to start the build today :)
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Can you get that sized box IN the trunk or are you building it in the trunk?
think I can fit it in.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Someone ?
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
You don't have enough room on the baffle for 4 12" subs(or 10s for that matter) :(
It would have to be a clamshell design and even at that, you dont have enough airspace for 4 12s
I could get this to work with 2 sub up and 2 to the front I think. But the port area sucks.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Yikes! I don't think you'd have a performing enclosure with subs positioned like that :(
I would hate to give any advice to an enclosure that would be loaded that way with subs.
Ya that's why I got on here to ask. I have ran sub up in a trunk before and it worked out vary good. But never subs up and front. So what u think should I just built a good 2-12 box? Keep the other 2 subs for back ups?
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Pic of my 18" ppi in the trunk. Worked vary well
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 847 Guests (See full list)
