AQ/SQ SDC 2.0 12's
chad190
Alright guys. Ordering 2 sdc 2.0's on Tuesday night. Would a JL 500/1 @2 ohms (after broken in) amp work well with these? Or go with the JL 360/2? And I have a previously built slot port box that is 3.8 cubes with 1.6 to each sub tuned @37 hz.
What do you think? Will this be a good setup for the subs? I will eventually build another box for them.
2006 Monte Carlo
Pioneer DEH-80PRS
2 SSA ZCON 12's
5 Cube Box tuned to 32 Hz
Soundqubed 3500.1
PAC LC-1
Singer 320 Amp Alt
XS D3100 & Kinetik HC2400 in trunk
Super Start AGM Under Hood
80ft+ Sky High 1/0
40 ft^3 120mil sky high deadener
Soundqubed Pro Audio 6.5" mids
Soundqubed Super Tweeters
Alpine 1" Tweeters
Alpine MRP-F300
250 a piece is fine for thoes subs ive seen then running 4-500 in the right box
post a few more specs on the box you have
as far as net, 1.75-2.5cuft net, sq recommends 16:1 on the port ratio but it rellate it comes down to power and net as the sub stays the same nomatter what the net
I only see one problem with the amps you want to run. The subs are duel 4ohm voice coil. Thus makes your final wiring options 4ohms or 1ohm.
So you need to find a amp that will do 500wrms at 4 ohms or 500rms at 1ohm. To e honest I would just get a 500 or close at 4ohms so if you decide to upgrade you will have headroom and not need to buy a new amp.
I personally would look at the soundqubed 1200
It does 500@4 and plenty more at 1ohm if you want to upgrade later
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
this is the box specs for the box i have built already
2006 Monte Carlo
Pioneer DEH-80PRS
2 SSA ZCON 12's
Soundqubed 3500.1
PAC LC-1
Singer 320 Amp Alt
80ft+ Sky High 1/0
Alpine 1" Tweeters
Alpine MRP-F300
  • Who's Online   0 Members, 0 Anonymous, 847 Guests (See full list)
