jeepbass1 Posted September 1, 2013 Report Posted September 1, 2013 So I have an 2004 jeep liberty with stock alternator with 1 run of 0 gauge + and 1 run of 0 gauge - going from the front battery to the rear amplifier sundown 3500. I have a relay wired to turn on the amp from the headunit... and I also had done the big 3 upgrade also...My ground and power have an ohm value of 0 ohms from ground of amp to - of battery and same goes for the + side.. also thr RCa's are no where near the power or ground cables.So my problem is popping noises when turning on the headunit and turning off the headunit and also lots of bass rumble even when no bass is playing.....So what can be done for this problem....
jarrius Posted September 1, 2013 Report Posted September 1, 2013 I would double check all your connections make sure there all tight and check your rca's and make sure there connected good. 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
jeepbass1 Posted September 1, 2013 Author Report Posted September 1, 2013 I would double check all your connections make sure there all tight and check your rca's and make sure there connected good. everything is super solid
justin0943 Posted September 1, 2013 Report Posted September 1, 2013 its gotta be the radio, what kind of radio do you have 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
jeepbass1 Posted September 2, 2013 Author Report Posted September 2, 2013 its gotta be the radio, what kind of radio do you have KDC-BT755HD
justin0943 Posted September 2, 2013 Report Posted September 2, 2013 thats a good radio so its could be the rca if you can get another hu if it still does it it may be the rca wires but if it stops then its the radio having a ground issue. 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Facekicker Posted September 2, 2013 Report Posted September 2, 2013 #1 check grounds on amp #2 try new rca wires (most likely problem imo) #3 check source (HU) I know you said everything is solid, but realize, everyone says that. Check your grounds again. Make sure your RCA's are firmly connected/inserted all the way. If connections are good, it's likely a signal issue from your RCAs or the headunit itself. 2002 Monte Carlo Started a build log Fi, DC, Mechman, XS Power
jeepbass1 Posted September 2, 2013 Author Report Posted September 2, 2013 thats a good radio so its could be the rca if you can get another hu if it still does it it may be the rca wires but if it stops then its the radio having a ground issue. #1 check grounds on amp #2 try new rca wires (most likely problem imo) #3 check source (HU) I know you said everything is solid, but realize, everyone says that. Check your grounds again. Make sure your RCA's are firmly connected/inserted all the way. If connections are good, it's likely a signal issue from your RCAs or the headunit itself. So its the cheap rca's i got cause as soon as I ran rockford rca's all the noises stoped.
justin0943 Posted September 2, 2013 Report Posted September 2, 2013 okay problem solved clad it was the cheap rca cable 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
