1999 SAAB 9-3 Convertible Subwoofer Setup: Help Please!
rampagerich
Hey guys I am having a hard time with my SAAB. My current setup is an Eclipse SW8122DVC in a .9 Sealed box being pushed by a Punch P1000X1D amp. The highs are all Infinity Kappa Components pushed by a Punch P500X4D amp. The head unit is an Alpine CDE-HD148BT. The problem I am having is the subwoofer just does not have enough kick behind it. The bass is sometimes extremely heavy and other times its very flat depending on what type of music I play. The question I have is should I upgrade to a better subwoofer that will provide better output? Should I use a vented enclosure instead of a sealed in a convertible? My subwoofer is currently facing up in the trunk space due to lack of truck height of only 12 inches. Let me know your thoughts because its driving me crazy toying with this current sub setup.
  • 3 weeks later...
personally I'd go to a larger sealed box, maybe around 1.25 cu. ft. instead of .9 cu.ft. A ported box is probably going to be twice as loud as a sealed but may take up twice as much area as a sealed would?
Now I do not know the specs. of this model the Eclipse website is down. So if you still have the owners manual, please let us know what the specs are, particularly the...
Vas
Qts
Fs
then we could help you out a bit more from there.
1974 VW Beetle
2- JL Audio 10w08 subs in ported fiberglass enclosure
Hifonics ZRXLP 6.5C (fronts)
Hifonics HRC 5.2C (rears)
500w Crunch powerzone amp (subs)
600w Crunch powerone amp (components)
3 farad power acoustics cap.
head unit- Planet Audio P385UA
Boss eq 1208
How much room do you have to work with? Can you pull off a good ported for that sub or even another one?
What's your musical preferences and how do you like your music to sound? This will affect what box design.
My audio system
HU - Kenwood KDC bt755HD
Subs - Sundown SA 10 -2
Amplifier - CT Sounds 900.1
Car - 2013 scion TC
"It matter's not what other's think about you as long as you are happy with who you are"
"Great people didn't not sit around and wait for great thing's to come their way, they laced up their shoes, went out kicked some ass and made them happen"
"Until you've taken a long walk in my size 11 you have no right to judge me"
Musical interests: We came as romans, A Day To Remember, Three Days Grace, Disturbed, Story Of The Year, Atreyu, Breaking Benjamin, rise against, bullet for my valentine, red, skillet, Volbeat, alterbridge, creed, T.I., B.o.B, Eminem, T-pain,
Vas
Qts
Fs
Great advice
What size is your trunk? Length and width? you gave the height as 12". How much of the trunk are you willing to sacrifice?
So I decided to scrap the 12 inch woofer and go with 2 10 inch woofers in a sealed box. I can put 2 10s in a total of 2 cubic feet. So each 10 will get 1 cubic foot facing the rear trunk. I finally figured that I had the 12 inch positioned wrong so I was losing all my bass having it up fired. I really do not have much trunk space for dual tens in a ported box. trunk dimensions are 36 inches width, height is 12, and depth is about 17 inches. The two 10s I am going with are RE Audio SE Pros. Do you guys know if those subs are decent? Thanks guys for all your help.
Why not a single 10 or 12 in a ported box
With the 1000rms u have you'll get some decent noise
You could even do 2x sa8 ported
If you spend the 340 your will to spend on the 2x 10
You'll get a far better single
Dc lvl4
Sundown x
Sq hdc3
Dd 3500
Rf T2
Alpine x
The list goes on for $300 subs that in a ported box will outperform dual 10 sealed
  • 1 month later...
So I upgraded to 2 RE SE Pro 10d2s . I built the box to RE specs 12 inches in height, 34 inches width, and 14.5 inches depth. I tuned the port to approximately 35 hz. Subs are facing the rear and port is also rear facing. I made sure to use an O scope for fine tuning and I think I finally found a balance in my convertible. I guess it's time to start matting the trunk to stop the rattles. Any you guys ever dealt with RE Audio subs? Are they any decent? Like I said in my earlier post I had an old Eclipse sub and don't really know what the decent brands are that have great longevity for daily abuse.
  • Who's Online   0 Members, 0 Anonymous, 5740 Guests (See full list)
