RCP Audio Posted September 12, 2013 Author Report Posted September 12, 2013 I tried all that and still getting the same problem PSN: Rcp_soundz Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at. I'll stick a 300 amp fuse in a potato and sell it to you for $2k. 1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
RCP Audio Posted September 12, 2013 Author Report Posted September 12, 2013 Double PSN: Rcp_soundz Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at. I'll stick a 300 amp fuse in a potato and sell it to you for $2k. 1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
PTG13 Posted September 12, 2013 Report Posted September 12, 2013 Damn... does the BIOS show the SSD in the top spot now? How were the cables "backwards", I assume you mean just swapped the SSD and HDD? Also I would say maybe try the other things I said before The other thing I saw was maybe look into the OnChip SATA3.0 Support. I would assume thats SATA 6.0 Gbps, maybe try turning that off. And under the OnChip SATA type, what options are there? Does anything you choose allow you to edit the two below it, the 4/5 type and RAID5 support?
RCP Audio Posted September 12, 2013 Author Report Posted September 12, 2013 http://www.youtube.com/watch?v=5Z7Iu1QIij8 PSN: Rcp_soundz Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at. I'll stick a 300 amp fuse in a potato and sell it to you for $2k. 1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
PTG13 Posted September 12, 2013 Report Posted September 12, 2013 Okay at this point it's pretty clear that it's something in the OS causing issues. Lets try these steps, in order. 1)Disconnect the HDD and ODD to rule those out of the problem. 2) Attempt to get into safe mode with networking and try and run chkdsk /f 3) Try using your windows disc (I think you said before that you have one) to use the command like and run a chkdsk /f (this has to be run in a special way, as the disc will not default to the Win install drive.) Running out of options here, and it's really starting to just become a waste of time. It might just come down to a reinstall of Windows. Would that be an option? Just kinda start over?
RCP Audio Posted September 12, 2013 Author Report Posted September 12, 2013 im currently trying to get it to boot to linux so that i can see whats on it, I know there isnt anything super important but its all the little things PSN: Rcp_soundz Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at. I'll stick a 300 amp fuse in a potato and sell it to you for $2k. 1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
RCP Audio Posted September 12, 2013 Author Report Posted September 12, 2013 and now i have to g to work meaning i have to to take this laptop back so i wont be able to download much more, but ive got my phone so i can keep taking videos PSN: Rcp_soundz Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at. I'll stick a 300 amp fuse in a potato and sell it to you for $2k. 1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
RCP Audio Posted September 12, 2013 Author Report Posted September 12, 2013 So I managed to flash to my old bios before all this shit happened. And it's still doing it I also copied my c folder into my 2nd hdd. So I'm going to reinstall now. Lol. I think it's the best option PSN: Rcp_soundz Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at. I'll stick a 300 amp fuse in a potato and sell it to you for $2k. 1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
RCP Audio Posted September 12, 2013 Author Report Posted September 12, 2013 So i reinstalled and now its allgood so thanks for the help and shit guys, when i get all my games installed again ill hit you up about why grid 2 isnt working hahaha PSN: Rcp_soundz Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at. I'll stick a 300 amp fuse in a potato and sell it to you for $2k. 1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
PTG13 Posted September 12, 2013 Report Posted September 12, 2013 No problem man, most likely it was just problems stacking on top of problems, not allowing us to fix it. And I looked up some stuff about GRID2, it seems like it's those .NET framework downloads that don't work through steam, gotta do them manually.
