CDetty Posted September 11, 2013 Report Posted September 11, 2013 Okay, so I'm borrowing an RE DTS-1000.1 from my friend to temporarily power one of my X12s until my amp gets here from db-r (Which it's been over a week and I've heard nothing from them?), but my problem is, when I switch on the car, the protect light instantly turns on and the power light starts flashing. So far I've changed my ground location, ran a new remote, new RCAs, and later today I'm going to check my fuse holder on my power wire. (The insulation on the wire looks kinda burnt by the fuse holder so I'll be cutting that section of wire out). If nothing works, I'm out of options. Anyone have any suggestions? 1999 Honda Civic- RIP 2003 Acura RSX Type-S
Kyblack76 Posted September 11, 2013 Report Posted September 11, 2013 Remove speaker leads... Turn on. if still does the same, your gonna know dbr really well... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
CDetty Posted September 11, 2013 Author Report Posted September 11, 2013 I pulled speaker leads and RCAs and it's still flashing the lights. What do you mean I'm going to get to know DB-R really well? 1999 Honda Civic- RIP 2003 Acura RSX Type-S
Kenyel Dotts Posted September 11, 2013 Report Posted September 11, 2013 W8 for the compaciters to die on the bored and then wash it with some type of electric cleaner. you can also dip it in water and let it dry out for a couple days. it could be loose wiring in the amp King dingalingIts not finished till i say so Bit@^!
Kyblack76 Posted September 11, 2013 Report Posted September 11, 2013 The amp will only protect from Thermal - which, is PROBABLY not it, due, to it not running. Impedance- which, you took out of the equasion, by removing the speaker leads Voltage- assuming you have 10-16 volts, your good. Hell the lights come on, so, im guessing your good there. The power supply in the amp just took a shit. Hence, you will know DBR really well. Sorry, it seems like you just fucked your buddys amp up. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
CDetty Posted September 11, 2013 Author Report Posted September 11, 2013 W8 for the compaciters to die on the bored and then wash it with some type of electric cleaner. you can also dip it in water and let it dry out for a couple days. it could be loose wiring in the amp I can kind of understand using electrical cleaner, but dipping an amp in water? Really now? The amp will only protect from Thermal - which, is PROBABLY not it, due, to it not running. Impedance- which, you took out of the equasion, by removing the speaker leads Voltage- assuming you have 10-16 volts, your good. Hell the lights come on, so, im guessing your good there. The power supply in the amp just took a shit. Hence, you will know DBR really well. Sorry, it seems like you just fucked your buddys amp up. Well shit. I'll still try and mess with the power wire but I guess I'll just pay to get it refurbished for him if I did fuck it up lol. 1999 Honda Civic- RIP 2003 Acura RSX Type-S
Kyblack76 Posted September 11, 2013 Report Posted September 11, 2013 Sorry bro. I hope you see something else. But, a protect at start up, with the speaker leads out, is not a good sign. Good luck. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
CDetty Posted September 11, 2013 Author Report Posted September 11, 2013 Sorry bro. I hope you see something else. But, a protect at start up, with the speaker leads out, is not a good sign. Good luck. Thanks man. I'm honestly just hoping I melted the fuse holder and the amp isn't getting any 12+ and it's just the current from the remote illuminating the protect light. I'd rather buy a new fuse and holder than a new amp hahaha. 1999 Honda Civic- RIP 2003 Acura RSX Type-S
Kenyel Dotts Posted September 11, 2013 Report Posted September 11, 2013 sounds crazy but they do this to circuit bordes all the time. they even do it to mother bordes I think they have a clip on you tube. as long as there is no power and compacitos are dead you can do it. King dingalingIts not finished till i say so Bit@^!
