Transmission question
Hey everyone, I have a quick question .. I have a 1999 Tiburon Base model with the 2.0 engine and the the transmission is going out in it. and i found another tib that has been damaged in the front and has 28k miles on it .. the guy is selling the whole car for 600. the problem is.. the car has a 1.8l engine.
so. my question is that will the 1.8 tranny work on my 2.0 engine?
2006 Monte Carlo
Pioneer DEH-80PRS
2 SSA ZCON 12's
5 Cube Box tuned to 32 Hz
Soundqubed 3500.1
PAC LC-1
Singer 320 Amp Alt
XS D3100 & Kinetik HC2400 in trunk
Super Start AGM Under Hood
80ft+ Sky High 1/0
40 ft^3 120mil sky high deadener
Soundqubed Pro Audio 6.5" mids
Soundqubed Super Tweeters
Alpine 1" Tweeters
Alpine MRP-F300
2006 Monte Carlo
Pioneer DEH-80PRS
2 SSA ZCON 12's
Soundqubed 3500.1
PAC LC-1
Singer 320 Amp Alt
80ft+ Sky High 1/0
Alpine 1" Tweeters
Alpine MRP-F300
As long as your '99 was made prior to June 1 1999 then yes you can use a '97 transmission. If your '99 was made after June 1st then you can only use transmissions from June 1st, 1999 - 2001
their both 4 cyl engine type trans and it should fit but the difference in how soon will that one go because of the 99s engine is bigger 2.0 more hp + torque most likely so is that tranny able to withhold that? if not then sooner or later it will go too.
Mine was made September 21, 1998
and that was also one of my concerns: if the more power would burn up that tranny because it's going on a bigger engine
2006 Monte Carlo
Pioneer DEH-80PRS
2 SSA ZCON 12's
Soundqubed 3500.1
PAC LC-1
Singer 320 Amp Alt
80ft+ Sky High 1/0
Alpine 1" Tweeters
Alpine MRP-F300
it will but if you look up specs of the car hp + toque ratings and if they are not drastically different meaning 30 -40 then thats bad but 10 - 20 you should be fine.
No it will not burn up anything the transmission used in every tiburon prior to 6/1/99 back to 97 are the same. Same internals, same bolt pattern, same everything.
So everything is good then. :D
Awesome, thanks guys!
2006 Monte Carlo
Pioneer DEH-80PRS
2 SSA ZCON 12's
Soundqubed 3500.1
PAC LC-1
Singer 320 Amp Alt
80ft+ Sky High 1/0
Alpine 1" Tweeters
Alpine MRP-F300
