chad190 Posted September 12, 2013 Report Share Posted September 12, 2013 Hey everyone, I have a quick question .. I have a 1999 Tiburon Base model with the 2.0 engine and the the transmission is going out in it. and i found another tib that has been damaged in the front and has 28k miles on it .. the guy is selling the whole car for 600. the problem is.. the car has a 1.8l engine. so. my question is that will the 1.8 tranny work on my 2.0 engine? 2006 Monte Carlo Pioneer DEH-80PRS 2 SSA ZCON 12's 5 Cube Box tuned to 32 Hz Soundqubed 3500.1 PAC LC-1 Singer 320 Amp Alt XS D3100 & Kinetik HC2400 in trunk Super Start AGM Under Hood 80ft+ Sky High 1/0 40 ft^3 120mil sky high deadener Soundqubed Pro Audio 6.5" mids Soundqubed Super Tweeters Alpine 1" Tweeters Alpine MRP-F300 Link to comment Share on other sites More sharing options...
Pioneerchuck Posted September 12, 2013 Report Share Posted September 12, 2013 What year is the damaged car? Link to comment Share on other sites More sharing options...
chad190 Posted September 12, 2013 Author Report Share Posted September 12, 2013 1997 2006 Monte Carlo Pioneer DEH-80PRS 2 SSA ZCON 12's 5 Cube Box tuned to 32 Hz Soundqubed 3500.1 PAC LC-1 Singer 320 Amp Alt XS D3100 & Kinetik HC2400 in trunk Super Start AGM Under Hood 80ft+ Sky High 1/0 40 ft^3 120mil sky high deadener Soundqubed Pro Audio 6.5" mids Soundqubed Super Tweeters Alpine 1" Tweeters Alpine MRP-F300 Link to comment Share on other sites More sharing options...
Pioneerchuck Posted September 12, 2013 Report Share Posted September 12, 2013 As long as your '99 was made prior to June 1 1999 then yes you can use a '97 transmission. If your '99 was made after June 1st then you can only use transmissions from June 1st, 1999 - 2001 Link to comment Share on other sites More sharing options...
Mr Godly Posted September 12, 2013 Report Share Posted September 12, 2013 their both 4 cyl engine type trans and it should fit but the difference in how soon will that one go because of the 99s engine is bigger 2.0 more hp + torque most likely so is that tranny able to withhold that? if not then sooner or later it will go too. Link to comment Share on other sites More sharing options...
chad190 Posted September 12, 2013 Author Report Share Posted September 12, 2013 Mine was made September 21, 1998 and that was also one of my concerns: if the more power would burn up that tranny because it's going on a bigger engine 2006 Monte Carlo Pioneer DEH-80PRS 2 SSA ZCON 12's 5 Cube Box tuned to 32 Hz Soundqubed 3500.1 PAC LC-1 Singer 320 Amp Alt XS D3100 & Kinetik HC2400 in trunk Super Start AGM Under Hood 80ft+ Sky High 1/0 40 ft^3 120mil sky high deadener Soundqubed Pro Audio 6.5" mids Soundqubed Super Tweeters Alpine 1" Tweeters Alpine MRP-F300 Link to comment Share on other sites More sharing options...
Mr Godly Posted September 12, 2013 Report Share Posted September 12, 2013 it will but if you look up specs of the car hp + toque ratings and if they are not drastically different meaning 30 -40 then thats bad but 10 - 20 you should be fine. Link to comment Share on other sites More sharing options...
Pioneerchuck Posted September 12, 2013 Report Share Posted September 12, 2013 No it will not burn up anything the transmission used in every tiburon prior to 6/1/99 back to 97 are the same. Same internals, same bolt pattern, same everything. Link to comment Share on other sites More sharing options...
Mr Godly Posted September 12, 2013 Report Share Posted September 12, 2013 No it will not burn up anything the transmission used in every tiburon prior to 6/1/99 back to 97 are the same. Same internals, same bolt pattern, same everything. So everything is good then. Link to comment Share on other sites More sharing options...
chad190 Posted September 12, 2013 Author Report Share Posted September 12, 2013 Awesome, thanks guys! 2006 Monte Carlo Pioneer DEH-80PRS 2 SSA ZCON 12's 5 Cube Box tuned to 32 Hz Soundqubed 3500.1 PAC LC-1 Singer 320 Amp Alt XS D3100 & Kinetik HC2400 in trunk Super Start AGM Under Hood 80ft+ Sky High 1/0 40 ft^3 120mil sky high deadener Soundqubed Pro Audio 6.5" mids Soundqubed Super Tweeters Alpine 1" Tweeters Alpine MRP-F300 Link to comment Share on other sites More sharing options...
