tburt915 Posted September 16, 2013 Report Posted September 16, 2013 Fs: 30.1 Hz Re: 0.7 Ohms/coil Qms: 7.65 Qes: .37 Qts: .36 Mms: 248g Cms: 0.11mm/N Sd: 480cm^2 Vas: 36.5 l Spl: 86.1dB 1W/1m Bl: 13.1 Xmax: 20mm Rms: 1000W Sealed box: .7-1.2 cuft Ported box: 1.8-2.5 cuft @ 33Hz Sub OD: 12.500” Cut ID: 11.125” Mounting depth: 6.500” Displacement: 0.14cuft this is the parameters. I plan on putting 2 12in fi ssds in an aero ported box. if anyone could help me out that would be greatly appreciated!
smashedz28 Posted September 16, 2013 Report Posted September 16, 2013 How the hell is anyone going to help you? Give your max dimensions for the box. Give some info on what your trying to do with this box and where your putting it
tburt915 Posted September 16, 2013 Author Report Posted September 16, 2013 max dimensions are 30w 16h any depth subs will be powered by a sundown saz1500d at 1 ohm will be going in my trunk of a 2007 honda accord main goal is sq wanting to try an aero port/ports
