1996 Impala SS JL Audio build
I'll share this build I did in a friends Impala with you guys. I will copy paste from the Impala Forum.
Going to kick this one off finally. I know you have seen some peaks in the show your trunks thread but I have a few more pics than that. Not everything is documented especially when I was working with the fiberglass resin or in a hurry but i do have some pics lol. This one has taken me a LOOOOOOONG time but we are seeing the light! I have learned ALOT on this build and i want to thank Juan for putting up the cash to build this thing and try some new thigs. To think the whole fiberglass part came about because we couldn't hide the battery with a straight wood panel lol.
Quick system rundown.
Alpine IVA-D310 already installed probably going to a Pioneer DEH-80PRS to have better active control.
Two 13w7 on two JL 1000/1's
Front stage is Image Dynamics CX62 mids in the doors and XS28 Tweets fiberglassed in the A-pillars run active off a JL 450/4
Epicenter for Juan's Cumbia's
Memphis 0 gauge
Optima redtop in the bay and Yellowtop in the rear.
Car in question.
Box cut. I usually always glass those angled joints.
464782_462828380406066_1329872225_o_zps7
616145_462828663739371_2070937760_o_zpsc
Mid off Polk DXI component set that was in there next to the Image Dynamics CX62 mid.
337769_462827247072846_2016725969_o_zps0
280852_462810863741151_1413842146_o_zps5
ID Mid installed in the door on a 1/2 inch baffle that was undercoated. Raammat and closed cell Foam was used to decouple the mid and baffle from the door.
325142_462827883739449_615298043_o_zpsf1
Measuring out the cut outs for one of the amp beauty panels.
621089_462827120406192_771498079_o_zpsa1
Just mocking it up. on the table before I put it in the car.
96 Impala SS
Memphis 2000D, Memphis ST-3004, MB Quart RAA-2400, Custom PSI Tc9 12 's
Ascendant Audio Poly Mids and Vifa XT25 tweets Active
97 RCSB Silverado
3way Crystal Comps, ID10 ported, Off a US acoustics 4085
In the trunk real quick to see what it's looking like. This is important. As you go you need to able to see what the next move is.
Frame work taking shape. It's got to be pretty strong so when you start stretching your mold fabric it doesn't move.
279711_468395943182643_444282378_o_zps51
The two beauty panels for the amps are in in these pics aswell. This will allow the two tone we are going for.
615712_468396073182630_370671551_o_zpsf3
Rear beauty panel starting to take shape.
327289_468412733180964_1493647856_o_zps0
Frame work for the rear beauty panel that covers the trunk latch thing pretty much done and almost ready to stretch the ponte material I used as mold fabric.
201088_470404329648471_788413071_o_zps94
201062_470404442981793_1450320199_o_zps5
Sorry for the cell shot but I can't always go run and grab the camera.
204291_470404642981773_1293108272_o_zps5
Started stretching fabric on the rear panel first. Took all the panels out and taped up what i didn't want to get resin on and layed down some plastic cover cloth to protect the equipment.
242128_470404849648419_1448259851_o_zps7
96 Impala SS
97 RCSB Silverado
Moved onto molding the front subwoofer beauty panel
620661_470405049648399_475460743_o_zps84
Juan helped stretch material and was here when we glassed all the panels cutting mat and laying it on while I applied the resin. He didn't know it was so much work! This is a couple of layers of mat on everything. After this I took all the panels out and did a few more layers of glass on the backside.
176950_496352563720314_398144377_o-1_zps
617198_496352467053657_1344667294_o_zps0
After this during the rain spell we had in Cali, Juan had some down time and took the car home and then proceeded to sand down the fiberglass to get it ready for filler. I don't have many filler pics but here are the side panels after some filler. My brother and "Silencio Lokote" came over a few nights to spread filler while I sanded.
291586_510248028997434_697550219_o_zps74
Here are the panels after filler and some primer to see where I'm at.
You can see my inserts in place that will give me that two tone we're after.
The trunk latch beauty panel has a really light coat of primer in these pics that's why it looks spotty.
96 Impala SS
97 RCSB Silverado
I don't have build pics of the fiberglass A-pillars but here's what i did. I cut out an MDF ring out of 1/4 inch MDF, installed the pillars in the car, Aim the rings a little bit more on axis, stretched ponte material to get the shape, resin the ponte, and then fill the inside with a duraglass milkshake I made. Here they are wrapped by Eddie at Backyard Custom Interiors in perforated material to match the seat inserts.
Shot of both pillars from about where the domelight is.
UH HUH. Sneak peak of the rear and sidepanels that were also wrapped by Eddie at Backyard Custom interiors.
Got these wrapped up and put together. What do you think?
Beginnings of the trunk lid cover.
**UPDATE**
Sidepanel put together. Still need to attach LEDS.
Closer shot of the Embossed Leaping deer.
Sneak peak at what the sidepanels will look like Lit. Routered some plexi to do this known as edge lit plexi. This is with only one led strip on the top. It will have leds on the whole perimeter to create an even glow.
858172_543387565683480_2089813376_o_zps8
96 Impala SS
97 RCSB Silverado
Getting the logo ready for embossing.
902174_559264260762477_1106207746_o_zps0
All done and attached to the outer piece of the trunk lid cover to give it that two tone look.
Here is an update for you guys. We are about 85% done just needs a logo cut and some other baby surprises.
LED's on.
892694_565862013436035_1277009788_o_zpsb
The leaping dears just pop on the sidepanels.
906612_565862153436021_712303975_o_zpsa5
Wait for it...wait for it...
Wait for it... wait for it...
892812_566607780028125_229404344_o_zpsed
906407_566607866694783_923967311_o_zps23
Trunk lid cover looks good one there.
901472_566607553361481_2060687452_o_zps9
96 Impala SS
97 RCSB Silverado
Finally got the logo in the way we wanted.
Amps were painted a "burgundy" color to match the trunk. Will get a shot of it during the day when I get a chance.
And here it is Done.
Like I said i pretty much copied this over from the Impala SS Forum. I don't own a shop or work at a shop. i just started doing small builds for fun and every car ashow we went too people asked "who built that." That's where my logo/signature came about. Let me know what you think.
Oh and there is plenty of clearance between the beauty panel and the subs for those wondering. pics are just decieving.
96 Impala SS
97 RCSB Silverado
That is pure sex man! That style impala is my favorite car of that era. I was 18 in '96 and drove an '86 LTD. I drooled over the Impala, a newer, better, FAST 4 door boat!
I assume you're kidding with the deers comments? You know those are impalas not deers?
Can you link to your thread on the impala forum? I want to see under the hood!
Awesome awesome build man!
_paralyzed_ in the Impala community we call them "Leaping Deer's".
This is not my car. This car has about 25,000 miles or so on it and The engine is bone stock other than a CAI and Exhaust.
96 Impala SS
97 RCSB Silverado
