Powering two vvx-10 skar subs
Chriskemp909
I have a Crunch Power Zone PZA1400.2 2 Channel Amplifier 350 x 2 @ 4 OHMS, 700 x 2 @ 2 OHMS - 1400 Watts x 1 @ 4 OHMS with Illuminated Badge in my trunk already.
I want to to buy two skar vvx-10" subwoofers. I was going to buy both woofers in 2ohms. I want to know how to wire them at 700 watts each? Or do I need the 4ohms?
Btw: I've been looking at crutchfeild and sonic electronics wiring diagrams but, I don't understand if there 700 watts each?
Thanks!
Those subs are 600 watt rms each. But they will handle the 700 rms just fine.
truthsayer
if you go with dual 2ohm you can do. 1/2, 2, or 8ohm
if you go with dual 4ohm you can do . 1 or 4ohm that would work for the amp you have, That will give you 700watts per sub @ 4 OHMS
2009 bmw 5 series
Head Unit Stock
Amplifier-JL Audio JX 360/4
Processor- Audiocontrol LC6
Just get 2 of the dvc 4 ohm and wire each sub to 2ohm. so wire the subs individualy in parralel. then wire the subs in series. this will give you a 4 ohm load to amp. go here http://www.bcae1.com/spkrmlti.htm, this will give you all the help you need.
truthsayer
get D4's. that way each woofer will see like 300rms or so when you bridge the amp at 4 ohms.
Thanks for the interest guys! So I did some reading and I think I get it
"This is the wiring diagram for woofers with dual 2 ohm voice coils. This will give you a 2 ohm load. The voice coils of each individual speakers are wired in series. This gives each speaker an 4 ohm impedance. Wiring them in parallel will present the amp with a 2 ohm load. You can calculate for more speakers by entering the number of speakers in the correct field."
So I am going to get 2 2ohm speakers and wire the speakers individual voice coiIs in series, making each speaker 4ohm, then I will wire them parceled to give the amp a 2ohm impendance? And deliver 700 watts x 2 @ 2ohms? Right?
Again, thanks for all your help!
no, the way you are talking, if this is a 2 channel amp. and wired like you said. each channel will be getting a 4 ohm load. get two dvc 4ohm subs. wire each sub in parralel for a 2ohm load each sub. so your 2 channel amp, each channel will be getting a 2ohm load. any confusion go back to http://www.bcae1.com/spkrmlti.htm.if yospk2dvcs.gifu want to wire them on 1 channel do this and this will give 1 channel with a 4ohm load. But if u want to wire useing 2 channels do as i stated above. so if you are wireing 2 channels and wire each sub in paralel you will present each channel a 2ohm load. hope this explains it for you.
truthsayer
ok i checked out your amp, and you can wire it either way like i said.
truthsayer
  • Who's Online   0 Members, 0 Anonymous, 6292 Guests (See full list)
