another rear battery question
Ok to start off I have a optima red top up front.. big 3 and 1 run to the back..all shok ind wire.. well I'm adding 2 c&d 55ahbatterys in my trunk.. do I NEED to add another run to the back (negative).. and should I ground to batts at the rear also? And can I ground my amp to the battery or do I need a seperate ground for the amp.. thanks!!
1999 grand prix gt
kenwood x994 head unit
1/0 big 3 all shok industry single run to the back
New mid/highs coming not sure what
Soundqubed q2200d at .5 (have)
2 soundqubed hdc3 12s (have)
New box to be built.. sealed firing forward (yet to be designed)
200 amp alt not sure exact size or manufactor xs power batts
if you ground amps to battery make sure your power wire is longer than the ground. in the best of worlds all the car audio electronics going to the same ground to avoid ground loops and to take best advantage of the big 3. from my experience atleast
  • Who's Online   1 Member, 0 Anonymous, 457 Guests (See full list)
