Amps and Ohms Question
i never really see people wire their subs to 4 ohms and buy a amp that puts out rms rated at 4 ohms.. thats costly and unnecessary you can find a amp that runs 1 ohm stable with dual 4 ohm subs wired to 1 ohm for $300 that does rated rms to each sub rather than buying a amp that does rated rms to each sub at 4 ohms for $1000. unless your electrical is really bad,
hopefully he wasnt trying to make you buy a bigger amp so he can make more money off you.
Amps and ohms, amps and ohms.
I gotta have me mo' amps and ohms
The wiring, the coils, the configuration
I run em parallel to get them subs pacin.
Hot hoes n chicken heads in my new whip,
I hope they swallow and play "just the tip"
I ride around the block and bump court to court
I feel that bass comin out my aeroport.
I need mo power so I drop impedance
Bass make the chicks wanna jump on my penis
Eclipse cd7000
I just called another store to price check (I looked online last night as nowhere is open on Sunday) and the guy pretty much said exactly what you guys have. There's no reason I'd need to wire at 4Ohm. No clue why the guy at the shop would have even suggested that as he didn't have anything that could push that out (Meaning I'd have to buy it elsewhere). But that store I called did say they have a Pioneer 1600 that is 1Ohm stable and will put out 800RMS @ 1Ohm. So sounds like I'm in luck. Would you guys trust that or get a different one?
i have three subs that are 2 ohm and im trying to wire them down to 1 ohm on a 1 ohm stable amp. either way i wire it it comes out to 1.33 ohm or .67 ohm. i was thinking about wiring the subs to 1 ohm each and run seperate wires to the amp instead of wiring them all together, does anyone have any other ideas that might help or information or recomendations. i am open to any opinions.
you talking about this one?
http://www.pioneerelectronics.com/PUSA/Car/Amplifiers/GM+Digital+Series/GM-D8601
depends how much you can get it for.
That's gotta be the one. He said on sale @ 169. Best Buy (place that's installing) wants 199. Sounded like a good deal. Will that amp put out rated though or am I better off shelling out a little more for a better brand?
170 aint bad. one guy mentioned meade did an amp dyno session with one of those pioneer amps and it did rated.
I appreciate all your help man! I will spring on that deal and hop over to BB for the install @ 1Ohm.
  • Who's Online   0 Members, 0 Anonymous, 720 Guests (See full list)
