soundsystemaniac Posted September 30, 2013 Report Posted September 30, 2013 I have been asking around for advice on this 4th order and have gotten a couple different replies and I wanted to see what the feedback here is. Car: 2012 Audi A4 Equipment: 2 DC level 4 12" M2, XS power d4900, 1 Crescendo Audio BC 2000 at 1 ohm Goals: play daily music from 32/33 hz to 65/70 hz with authority and Flat! Constraints- will be ported through rear deck. I have ~ 7cubes before any displacements to play with. I have gotten feedback of doing 1.3 sealed and 4 ported with 55 sq inches of port @ 50 hz. I have also gotten doing a 1:1 or 1:1.5 ratio to keep the response flat. Whats your advice? Thanks in advance! Chevy astro 2 18s and 9k rms Walled!http://www.stevemead...rms-42-inch-tv/JEEP GRAN CHEROKEE SRT8 BUILD!2 JL AUDIO 15s trunk buildDC XL 15 buildDC level 3 18 buildhttp://www.stevemead...verunner-build/ http://www.facebook....hp?id=646651228
vetkilr01 Posted September 30, 2013 Report Posted September 30, 2013 Thats almost exactly what mine where just in, but tuned to 46 hz. Was very flat and played low, that amp is to small IMO...I was running a bc3500 and they were laughing at it. Rise is high in a 4th order, mine was wired to .5 but rose to almost 3 ohms.
soundsystemaniac Posted October 1, 2013 Author Report Posted October 1, 2013 Thats almost exactly what mine where just in, but tuned to 46 hz. Was very flat and played low, that amp is to small IMO...I was running a bc3500 and they were laughing at it. Rise is high in a 4th order, mine was wired to .5 but rose to almost 3 ohms. the 1.3 sealed and 4 ported? Chevy astro 2 18s and 9k rms Walled!http://www.stevemead...rms-42-inch-tv/JEEP GRAN CHEROKEE SRT8 BUILD!2 JL AUDIO 15s trunk buildDC XL 15 buildDC level 3 18 buildhttp://www.stevemead...verunner-build/ http://www.facebook....hp?id=646651228
soundsystemaniac Posted October 4, 2013 Author Report Posted October 4, 2013 This Is what I have come up with. 1 cubic sealed for each sub plus displacement of .18 gives me 1.18 cubes sealed per sub. 2.5 net ported at 49.xx hz with 49 sq inches of port. Do you guys think this will work? Chevy astro 2 18s and 9k rms Walled!http://www.stevemead...rms-42-inch-tv/JEEP GRAN CHEROKEE SRT8 BUILD!2 JL AUDIO 15s trunk buildDC XL 15 buildDC level 3 18 buildhttp://www.stevemead...verunner-build/ http://www.facebook....hp?id=646651228
Purplehaze Posted October 4, 2013 Report Posted October 4, 2013 This Is what I have come up with. 1 cubic sealed for each sub plus displacement of .18 gives me 1.18 cubes sealed per sub. 2.5 net ported at 49.xx hz with 49 sq inches of port. Do you guys think this will work? You have to subtract the displacement, unless you are mounting inverted. So it would be 1 cube - .18 or = 0.82ft^3 per chamber. The sub takes volume away from the chamber. Kickin' Cruiser Seller Feedback Stage 3 Dash, Door Panels,4th Order wall 4 - 15'son a DC 5.0K 2 DC 5.0K'sSolo X 15 (v.2) Sub Build
vetkilr01 Posted October 4, 2013 Report Posted October 4, 2013 Exactly...sealed box to small ported as well. Mine was 1.2 after displacement sealed and 4 cubes ported with 50 squares
soundsystemaniac Posted October 4, 2013 Author Report Posted October 4, 2013 Exactly...sealed box to small ported as well. Mine was 1.2 after displacement sealed and 4 cubes ported with 50 squares This Is what I have come up with. 1 cubic sealed for each sub plus displacement of .18 gives me 1.18 cubes sealed per sub. 2.5 net ported at 49.xx hz with 49 sq inches of port. Do you guys think this will work? You have to subtract the displacement, unless you are mounting inverted. So it would be 1 cube - .18 or = 0.82ft^3 per chamber. The sub takes volume away from the chamber. Well, I worded that wrong lol. The total volume of the sealed chambers is 1.18^ft3. Chevy astro 2 18s and 9k rms Walled!http://www.stevemead...rms-42-inch-tv/JEEP GRAN CHEROKEE SRT8 BUILD!2 JL AUDIO 15s trunk buildDC XL 15 buildDC level 3 18 buildhttp://www.stevemead...verunner-build/ http://www.facebook....hp?id=646651228
vetkilr01 Posted October 4, 2013 Report Posted October 4, 2013 http://www.youtube.com/watch?v=KZfHFZ5VZJo&feature=youtu.be heres a old vid of my 2 level 4s in a 4th running on a BC3500.
