please help with treo ssx18 box
greg4510
o ok well the 2 3000.1 would give each woofer about 2500 rms a piece but i have to send one back. i have a 3000.5 laying around that would split 2500rms between both until iget the other amp. what i was asking was if i were to only give each woofer about 1250 rms with the box specs you gave would it work for the time bieng
sorry another question i always hear about when bending a port you habe to leave the same amount of space off the back wall that the port is wide but this port is 7 inches wide would the same formula apply to this. my box is only going to be 21.5 inches deep so how would that work out?
And since the port will be like a T and turn 90°, you need to halve the width. So the port section that is parallel with the back wall of the box(furthest away from port opening) will need to be 3.5". Those subs would be fine to be underpowered for the time being I'm sure, I don't think you would need to shrink any volume since they are rated at 2500W RMS, aren't they?
  • Who's Online   0 Members, 0 Anonymous, 1319 Guests (See full list)
