Ground Zero GZNA 1.2500DXII
Bass_Maniak
the result is that you did that 49voltX50amps...if i am correct you get the message of 2450...the result might be possible if you cllamped at 14,4V
if you had a drop of voltage at 12,1 you get slightly different results....
also the main results of tested dragster 3001--done by a dyno amp tester on a local shop nearby 6 or 7 months ago..
4144W x 1 RMS @1 ohm (15.6V)
2792W x 1 RMS @1 ohm (14.2V)
1443W x 1RMS @2 ohm (14.2V)
730W x 1 RMS @4 ohm (14.2V)
so there is no way you got 3900watts on 13,3V rough if it is claimed
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
and you studied physics at the 5th grade ...? that in connection with the nominal 0.25 ohms will be at least 0.7! and even more! so the amplifier in any case will not work in nominal 0.25! so that children learn materiel. and in the car we have a 14.4 as the system 16volt.
EDIT..nevermind....
how did you make a car to work at 16V??
aksi even if you had a 16v sistem..with such a drowndown of voltage you still could not be making that much of a power...simple enough...
on the other hand,,,please...test you amplifier with a running car...not batterys in the house
ps...whats that green dynamite stiff connected to teh batts??
Whether or not Ground Zero does its numbers or not there are not many people or any here that would wanna spend upward and over $2,000 an amplifier. If they did there are more reputable companies like TRU, Mosconi, Morel etc, that you can get a bad ass amp for around $700-$900. Plain and simple me personaly feel your amps are waaaaaaaayyyyy too pricey. You can get an entire quality setup for what your asking per amp.
