rexxx15d2 kicker kx1600.1
I have 2 new rexxx15d2 subs and 4 kicker kx1600.1 amps. Im going to put two amps on each sum one on each coil. Will these subs handle the power in a 10 cu ft box tuned to 32 hz. With gains n setting properly set. How reliable are these subs? With using four amps I think setting the gains evenly will be very important is a voltmeter accurate enough. Thanks. Would the smd d1 work in this application to set the amps thanks
hmmm sucks those subs are dual 2 ohm not dual 4 ohm so you could run one amp per sub since the sub is only 1500watts rms 2 amps per sub is kinda overkill i use the kx1600 on my orion hcca 10 thats 1500watts rms.
I have read rms is 2000 and 4000 max ?
a sorry i looked it up on sonic and forgot one of the x's
your right its 2k http://www.sonicelectronix.com/item_36696_RE-Audio-XXX15D4.html
do you already own the sub and amps ???? if not i would suggestbuying the d4 not the d2 or using diffrent amps that are 1 ohm stable so you dont need to many amps. seems like you could save money buy buying
2x re xxxx 15d4
2x kicker kx2400
Rethink your amps, if you ask me. I would look at a Bass Clef 2000.1 or even a Hifonics BRZ 2100 for the money involved in those Kickers. You have no reason to put an amp on each coil, and it will only complicate and lengthen your install.
I run some XXX 15's in a few different setups and they will take 2k RMS happily, 3K daily will make em stinky.
edit:
ghostly he's better off with the D2's and a 1 ohm stable amp on each one. The only reason you'd want D4's is if you were going to put both subs on one big amp or you only had amps that are 2 ohm stable.
edit:
ah ok i was avoiding the strapping i have never dealt with these subs i have to admit in this case i would probably look more into diffrent amps that are 1 ohm stable ^^
Those amps put out their power at 2 ohms, you should have bought D4 subs if planning to run one amp per coil. Aside from that, you should NOT be waiting to send over 3K a piece to those subs. These are more of a sound quality and detailed subwoofer, there is no need to overpower by 50% . I would either re think you're sub voice coil choice, or you're amplifier choice. Unless you have a crazy hookup on those amps, that aren't cheap. Neither are the subs for that matter. I'd prefer running both subs on 1 amp for simplicity reasons. If you have the budget for what those amps normally sell for, than you have plenty to get a larger amp that can feed 2 of those subs very well.
Edit- You ninja'd me. Do you own the subs yet?
I already had two amps and two 15L7s and wanted to get louder so I thought it would be best to get two more amps and some better speakerz. Are the xxxs gonna be alot better the the L7s?
  • Who's Online   2 Members, 1 Anonymous, 652 Guests (See full list)
