Deadly hertzz Posted October 13, 2013 Report Posted October 13, 2013 How do I set the gain on my saz 3000d just upgraded as I use an audio control overdrive line driver but the gain voltage isn't marked on the amp so was wondering what's the highest voltage on the gain usually set it to 9 an the line driver to 9 at 3/4 volume any helps appreciated 8 sundown sa 12s walledSaz3000 at .5HO altAll ofc Sky high wireAlpine componentsRockford power mids
KillaCam Posted October 13, 2013 Report Posted October 13, 2013 It's supposed to be set to match the output voltage on your hu. No one can really give a definite answer to this. The only way is to set the gains right with a proper device. And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log
Deadly hertzz Posted October 13, 2013 Author Report Posted October 13, 2013 I kno how to set the gains without the line driver but with the driver you set the amps gain to 9v then the line driver has lights on it and blips at the 9v at 3/4 volume but on most amps on the gain knob the voltages are marked but not on this amp 8 sundown sa 12s walledSaz3000 at .5HO altAll ofc Sky high wireAlpine componentsRockford power mids
