big 3 this will help you get more juice out of your alternator to actuallyy charge you batts by running a main power cable from the alt to the main batts but you need to follow the instruction so you can ground everything right i can get you one
2010 Mazda 3
*Rebuild Time*
Subs - (2) AA Mayhems 12's
Sub amp - (1) Populus Audio TPA 6500
Headunit - Pioneer App Radio 2
Batteries - XS Power (1) D3100 up front | 6 XP950 rear
Wire - Sky High 1/0 Gauge wires and RCA's and steve's VM1
Alternator - Singer 260 Externally Regulated
Front Stage: (2) PRV Audio 10W650A (4) PRV Audio 8MR500-PhP-4 (4) DS Bullet Tweets | (2) 6.5 Components (Rear doors)
Mids & high Amp : (2) Populus Audio 100.4
Processor: Rockford 3sixty.3
The Build Log : http://www.stevemeadedesigns.com/board/topic/175922-2010-mazda-3-2-aa-mayhems-12-pg14-new-video/page-11
1. 1/0 chassi ground
2. 1/0 alternator positive to battery positive
3. 1/0 alternator negative to battery negative
here is a video as well
2010 Mazda 3
*Rebuild Time*
yes sir ^^^^^ thats correct with the fuse
2010 Mazda 3
*Rebuild Time*
Ok actually on the (-) and directly connect it to ground.
Thou advise me to connect a (-) on the Alternator Everyone taking a stroll in addition to the mass.?
you need to add another ground from alt to car frame
2010 Mazda 3
*Rebuild Time*
I made this pattern with respect to the video.
suddenly I saw that I had not put a mass alternator
So I made ​​from the alternator (+) to the main battery (engine)
The (-) on the main battery (engine)
and alternator I made ​​from a mass on the frame.
it actually cable :)
this is how mine should look
2010 Mazda 3
*Rebuild Time*
