Quad Power Inputs
If I strap to aq 3500s that will be 4 power inputs and 4 ground inputs. I run sky high 1/0 ofc. Should I run 4 runs from my front battery to my rear bank then one run to each amp input? I am assuming this would be correct since I have to have 200 amps of fusing per input. If so I will also run 4 runs of ground front to back and 4 runs of positive between the alt and front battery just for peace of mind.
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
Nobody?
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
Alt is dc xp 270. Biggest I can get and nobody makes a dualmalt bracket. Raesr bank will be 4 d3100s and also will have the one d3100 under the hood for 5 total
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
I'm just going to assume your running 1 alt 300 amps or less with a nice size battery bank. If that's the case you'll be fine with 2+ and 2- runs from the front to the rear bank. If the alt is only a couple feet from the front battery a single run of 1/0 from alt to front battery is all you need.
4 fully loaded Fi sp4 15's
2 Crescendo bc5500s
Crescendo c1100.4
6 focal mids
Vifa tweets
5 XS Power d3100's
Pioneer avh-p4200dvd
All crammed into a mustang.
http://www.stevemeadedesigns.com/board/topic/150569-mikeg321s-fi-nendo-mustang-getting-walled-videos-page-4/
  • Who's Online   0 Members, 0 Anonymous, 2742 Guests (See full list)
