g2shuck Posted October 28, 2013 Report Posted October 28, 2013 To wire 8 DVC 4 ohm subs to a mono amp at 1 ohm you would wire 4 down to 2 ohms, other 4 to 2 ohms, then those to a 1 ohm final load correct? Here is a terrible drawing I made to show what I mean. 2000 Toyota Camry With Sealed Off Trunk Sky High OFC Wiring DC Power 270 XP Alt AQ 2200 Sub Amp Two DC Level 4 m2 12s 80 Mil Murdetmat Gathering Parts For Wall Build. Team DC Audio 2014 Member
bkolfo4 Posted October 28, 2013 Report Posted October 28, 2013 Yes Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
g2shuck Posted October 28, 2013 Author Report Posted October 28, 2013 Awesome that is what I thought but want you get to wiring so many together I feel better getting double checked lol 2000 Toyota Camry With Sealed Off Trunk Sky High OFC Wiring DC Power 270 XP Alt AQ 2200 Sub Amp Two DC Level 4 m2 12s 80 Mil Murdetmat Gathering Parts For Wall Build. Team DC Audio 2014 Member
gmsierra2000 Posted October 28, 2013 Report Posted October 28, 2013 if you have a volt meter you can check your ohms after wiring them all up the way you want and the two wires going to the final amp terminals you can meter them and it will tell you exactly what ohms you are putting towards your amp
bkolfo4 Posted October 29, 2013 Report Posted October 29, 2013 If you use the DCR and you have good connections. Should see 0.7-0.8 with a volt meter. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
