Amp shorting out? Help needed
SICKSPD
Hi I have a Hifonics Brutus 1700 watt amp that Ive had for the past year and a half I believe. The past couple months Ive had problems I believe to be caused by it. Im running two alpine type rs and when the bass knob is turned down almost all the way the bass seems relatively clean and normal, but once the bass to the subs is adjusted higher than around 30% or more the bass starts getting muffled and extremely distorted, I'm not sure what the exact word for it is though. Ive ruled out the subs being the problem, but the only other cause could have to do with my Pioneer head unit. Since last winter every morning when its even slightly cold out it wont even turn on. It's not until it warms up outside that it seems to turn on and during spring/fall/summer this problem is non-existent. Anybody have any guesses as to what my bass problem could be? and if the headunit problem is a separate issue, any ideas what that could be about?
Thanks
09 Challenger R/T (Audio system under construction):
  • Pioneer AVH-X4500BT (PAC RP4CH11 harness)
  • (2) Sundown Audio SA-8v2 (inverted)
  • CT Sounds AT1400.1D
  • XS Power D3400
  • 40 sq ft. Audiotechnix deadener
  • 1/0 Audiotechnix wiring
  • stock Boston Acoustic 7 speaker amplified system (for now)
  • Sealed trunk enclosure
Build log:
http://www.stevemeadedesigns.com/board/topic/178399-slammed-dodge-challenger-sundownct-sounds-build/
TEAM GOAT
Clipping
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
x2 clipping the shit out of the amp. bass boost is bad.
have you checked to see if the remote wire terminal on the amp is seeing over 12v when it's cold out and the amp won't turn on?
X3 turn clipping
Turn down your gain and turn your bass boost off.
How did you tune your amp?
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
The amp adjustments are the same as they were when it was performing as it should. The bass control I was referring to was just the sub level knob on my clarion equalizer.
Also, when the headunit wont come on none of the other audio equipment is powered up either. I'm assuming because theirs no power in the headunit to signal the remote wire on the amps and equalizer. So can there be an actual correlation between the temperature outside affecting audio equipment? It cant be just coincidence...
  • XS Power D3400
Build log:
TEAM GOAT
well cold shrinks things ever so slightly. maybe a connection on your radio harness is bad. or the pins that connect the faceplate to the radio body. I've heard that happening too
So if its not just poor adjustments on amp settings, what else could this clipping be caused by? Amp internals going out?
  • XS Power D3400
Build log:
TEAM GOAT
Run a ipod directly to amp and see if it still happens.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
I think Kranny is on the right path. Believe it or not removable face plates are a common failure due to the cold and the incredibly small board in them. They crack in the winter, loose a solder. Ive seen this happen so many times. I never remove my face plate after having to replace one. You can check your connections but i'll bet it's your face plate.
truthsayer
Well its a Pioneer AVH-P6300 flip screen. the face plate isnt really much of a faceplate at all, and its only been removed maybe like 3 times..ever lol
  • XS Power D3400
Build log:
TEAM GOAT
  • Who's Online   0 Members, 0 Anonymous, 671 Guests (See full list)
