Chevyboy's 4 15's walled on 7k - UBL
box getting bondo'd and painted with a little router work on the edges.
you can post comments here = http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-2-15s-7krms-ext-cab-1504-db/
added new batteries from XS power.
ended up only doing a 148.1 @ 33hz......
SO I CHANGED IT UP!
Thanks to Kevosinn, swapped out to 2 HDC4 15's.
metered it again today, with the HDC4's my peak rose to 35hz.
from 3 HDC3 15's @ .67, to 2 HDC4's @ 1, i gained 0.9 db.
did a 149 @ 35hz.
planning on doing more power, because i cant get the HDC4's to full extension, can get them about 70% xmax.
dropped in the AT-7000.1, and with a just a simple gain raise to about 1/4, which is ~3v. Broke a 50. Amp has PLENTY more in it, just need to beef up the electrical again a bit as far as reserve maybe.
And to continue with the CT Sounds classiness of solid white.... my new console amplifier
decided to try something. Swapping out the plug in the 3rd sub hole to a plugg-able port. So now i can change from 33hz to 40hz to see if i gain anything on the meter. Goes from ~100sqin of port to ~150sq in.
can post comments : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-2-15s-7krms-ext-cab-1504-db/
