keeping steady voltage
hey guys, i havent been on in awhile but i do have a question. so ive gone to 3 comps this summer, 2 with my old 160 amp alt and big 3 upgrade and a smaller stinger battery along with my reg battery. during those comps....ik its bad but my voltage dropped into the 10's.. so i bought a 350 amp singer alt and it works fantastic, voltage is always 14.1 or 14 with everything on and music playing and all that. when i went to the 3rd comp with that, my voltage dropped to like 12.3 during the run and ive got 2 12 inch t1s running off a t2500.1bd. at 1 ohm.... ik im feeding them a lot of power but there is no distortion or anything used dd-1 with -10db track. im just wondering should it get that low? with that alt or do i just need even another battery or something? llol im looking to upgrade bigger next yr so im just trying to get everything figured out, thx a lot for the input in advance guys
1995 Blazer lt 4dr
2 t1d412s
1 t2500.1bd
4 polk audio door speakers
2 dash speakers(coming soon)
1 amp to run my mids and highs(coming soon)
if it suddenly dropped to 12.3, that means your battery is not holding charge anymore or alternators regulator went bad.
Running 2500wrms on 2 small batteries is pretty risky tbh. Grab a D3100 or something similar and you'll be good.
just bought a yellow top optima for my starter battery recently, havent put it in but im plannin on gettin a couple more batteries for the back then cuz im gonna upgrade to 2 dc xls and another t2500 next yr haha but regardless of that, the 350 amp singer should be able to keep up with that shouldnt it?
1995 Blazer lt 4dr
2 t1d412s
1 t2500.1bd
I;m with loudbimmer. battery not holding a charge or bad regulator. Just test it to find out.
truthsayer
i run 2 DD m3b off of a singer 350 and 2 D3100s. drop to 12.8-13.2 depending on frequency. no clipping. if i start to soft clip voltage drops.
my advice would be to check connections, check grounds and check components.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
with the dmm the singer is puttin out 14.2 steady but the battery charge at reast is like 12.1??? the starter battery that is, the stinger batt in the back is like 12.8 i think last time i checked.. so just install the new optima i got and things should be alright for now?
1995 Blazer lt 4dr
2 t1d412s
1 t2500.1bd
double post
1995 Blazer lt 4dr
2 t1d412s
1 t2500.1bd
double post
1995 Blazer lt 4dr
2 t1d412s
1 t2500.1bd
try changing starter batt. but how do you have 2 different voltages between the batteries? did you disconnect for the readings
BMW M340 xDrive
i did, should i have kept them together? i thought they should be isolated from each other for testing?
1995 Blazer lt 4dr
2 t1d412s
1 t2500.1bd
  • Who's Online   0 Members, 0 Anonymous, 3129 Guests (See full list)
