Blockshaker101 Posted November 6, 2013 Report Posted November 6, 2013 hey guys i was wondering on the best bluetooth devise out there so i can stream my iphone to my factory radio. i want good sound quality. or can i go with an eq with an aux and then convert the speaker wire to rca and then back to wire after the eq. or do those rca to wire adapters suck. thanks in advance
Soccerballzs Posted November 6, 2013 Report Posted November 6, 2013 You are not going to get any quality sound from Bluetooth. Direct wire for is best for quality sound. Iphone music files loose a lot of dynamics from compressing file down. Use a hard drive in glove box and use a straight wave file does not compress it and sounds beautiful. This format requires a lot GB. I use a Toshiba 1TB in my. Over 500gb used for CD's. http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
Blockshaker101 Posted November 6, 2013 Author Report Posted November 6, 2013 ok so how do i hook up to factory stereo
Mustang06331 Posted November 8, 2013 Report Posted November 8, 2013 I have pretty good luck w the jabra cruiser 2 and the Motorola t505 ,only used in OEM application so can't comment on sound quality transfer
Jessica Posted November 8, 2013 Report Posted November 8, 2013 Well, lets talk about this for a second. What do you consider Sound quallity? A lot of people i have met cannot tell the difference between bluetooth and two cats having sex. If you fit this catoagory then i would say just pick any random device and enjoy it. Now, if you have an ear on each side of your head and you have not stabbed them repeatedly with meat thermormeters then i would recommend using an cable to connect your device to an aux in on your headunit. Of course, use the highest bit rate said device will allow. In my opinion 320kpbs mp3's are close enough to cd's for us. Some guys swear by lossless, but unless you are competing in sq you wont hear any difference while cruising around. just my .02 Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
