Can Box Burn Coil?
gattiboy13
I wouldn't listen to sony. enclosure and woofer can in fact affect it. Take loading into example, and take putting 10kw on a 100w sub. For sure check the gains. You power wire seems maybe a bit small to me IMO. Could be clipping from wrong gains, or could have voltage drop, could have a loading issue, or could just be burning off some excess glue. I'd start with checking your voltage drop and setting your gains.
Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893
real men dont use fuses :D
Neither do morons
Says the guy with lambo doors on his Ford Taurus.
Jeejeee..neither do I :P
Can be that varnish only smells,but I'd be more worried about why it is warming up also..even "low volume".
But you have already checked right wiring,there are no phase differences,amps voltage are normal? How much amp give "speaker voltages (VAC)" when it starts to smell?
Sub and port are the same wall? How much space is at the gate and the rear wall between? "Reverse" mounting or "normal"..if it´s normal way,so how much space is there the magnet and the rear wall between?
You would need to know the length of your port to find out it's exact volume and tuning. Just from me throwing the dims you gave into Torres it looks like no matter what your port length is your enclosure is way off in either the Tuning or wayyyy to much port area. Chances are the coil on that woofer is going to fail if you keep playing it in that enclosure. The best advice I could give you is ditch it right away and build another you don't have to question.
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
I think his port is 1.5X10.5" , that's only 15.75" of port. That's less than half the port I'd personally give the sub if it were in my vehicle.
The only one who can burn it,is the user himself. Box or the power doesn´t effect to it :)
I must argue with that. a wall socket mated with just about any sub can tell you that too much power can be bad for a sub. go ahead and try it.
<img src=http://i1332.photobucket.com/albums/w610/beastly666bassboy/IMG_9611192581855_zps9b9b76be.jpg border=0 alt= height="75" width="800">
Growing old is necessary... growing up is an option! Have fun or you might as well fall into a 6 foot deep hole. Its much easier to be smart and act stupid then it is to be stupid and act smart! You're only limited by your imagination! Stop limiting yourself! Optima yellow top6 guage cableJVC KD S36 headunitPower acoustik 1600w 750w rms @2 ohmsTwo MTX thunder 7000 10"sSealed box @4.04 ft^3Mojo Mat in the trunk Coming soon:1/0 awg cablebig 3... in 6 gauge(till i can get the money for 0)planet audio Crossover.2- 3.5's for the front.2- 6.5's for the doors2- 6x9's for the rear3- MB Quartz amps to power it all.1- 6" aeroport...soon! <p>My Log!
  • Who's Online   0 Members, 0 Anonymous, 3225 Guests (See full list)
