Tarnish on billet wheels, is there a fast way to restore them?
i own a semi. every spring all of my aluminum gets sanded down.
usually 280 grit 400 grit 600 grit 800 grit and then 1000 grit on a DA sander.
then using a buffer with proper wheels and dry compounds i start the polishing process.
Zephyr makes the wheels and compounds that i use.
you will need some small bobbins and a good die grinder in your application. you will like the results if you take the time to do them this way!!
  • Who's Online   0 Members, 0 Anonymous, 760 Guests (See full list)
