gattiboy13 Posted November 22, 2013 Report Posted November 22, 2013 Having only 1" between back of box and sub bottom should be ok right? Will this cause heating?
jarrius Posted November 22, 2013 Report Posted November 22, 2013 I personally would not be happy with that seems like it may restrict air movement from the sub and may be loss of out put. But I have been known to be wrong..... A lot lol 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
CleanSierra Posted November 22, 2013 Report Posted November 22, 2013 It really depends on the sub specifically. Which sub do you have this question about? Im not the one you want to try to troll. Just a fyi for you.
CleanSierra Posted November 22, 2013 Report Posted November 22, 2013 That sub had one pole vent and 6 smaller holes to vent the gap. Id contact Sundown and ask them their opinion. I wouldn't feel comfortable personally, with only an inch of clearance between the back of the motor and a wall of an enclosure. Im not the one you want to try to troll. Just a fyi for you.
gattiboy13 Posted November 22, 2013 Author Report Posted November 22, 2013 Well they at sundown designed me a box with a 2 inch space so I assume 1 will be ok. Thanks guys I always appreciate your input and advice.
CleanSierra Posted November 22, 2013 Report Posted November 22, 2013 one inch is different than two. Go with the design Sundown gave you, don't modify it. Smh Im not the one you want to try to troll. Just a fyi for you.
gattiboy13 Posted November 22, 2013 Author Report Posted November 22, 2013 Whats smh? Youngsters and your abbreviations.
truthsayer Posted November 22, 2013 Report Posted November 22, 2013 If your worried about the 1'' and sundown said 2'' would be fine. Just throw on a 1'' spacer for the sub. Problem solved. truthsayer
