shanesauce Posted November 24, 2013 Report Posted November 24, 2013 In the torres calculator, the port area rises with the port length. In all of the calculation I see online port area is only port widthxport height. If port area is raised as the port length increases what is the calculation because I can't use torres at work. - 2012 Mustang 3.7 Manual - Audio under construction
Omega5002 Posted November 24, 2013 Report Posted November 24, 2013 The total port area doesn't change, the per cube does because the extra length is taking up airspace. 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
revoracing247 Posted November 24, 2013 Report Posted November 24, 2013 port area shouldn't change with port length. are you sure your not putting int like "desired gross volume" or something thats making it compensate for something? i've never had torres do this for me before edit: ninja'd, didn't even think he could be looking at the port area per cube ~ If it was easy, everybody would be doing it ~
shanesauce Posted November 24, 2013 Author Report Posted November 24, 2013 Wow it all makes sense now... Thanks again, new torres user here lol - 2012 Mustang 3.7 Manual - Audio under construction
