Desousa93 Posted November 25, 2013 Report Posted November 25, 2013 Is it safe to run SA-12's on 1000 Wats rms per sub in this box below? i want to make sure everything seems okay before i blow up some subs.. So here's a suggestion, subs will take 1K each, use your amp subsonic filter to 28Hz: Port parts are as follows: 2 x Front to Back: 17 3/8" x 13 3/4"2 x Extension: 2 11/16" x 13 3/4" If you want to do 45s here's how to do them: New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
thefourth Posted November 25, 2013 Report Posted November 25, 2013 They should be fine. I've seen people run more than 1k per on clean power. Those subs can take some abuse. Thanks alaskanzx5 I might just do thatI can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream. oh lawd.
boom50cal Posted November 25, 2013 Report Posted November 25, 2013 Clean and steady power, yes. Listen to Joe X, he knows his stuff My judgement of that, Raptorman's one of many builds... http://youtu.be/5G7LTbAHZrk On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
fox_racin4 Posted November 25, 2013 Report Posted November 25, 2013 Ran 1600rms to each of my sa10s 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
Desousa93 Posted November 25, 2013 Author Report Posted November 25, 2013 Clean and steady power, yes. Listen to Joe X, he knows his stuff My judgement of that, Raptorman's one of many builds... Didnt know just double and triple checking eveeything Thabks guys New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
