stilltippin863 Posted March 5, 2008 Report Posted March 5, 2008 can a amp that pull less amps over power a amp that pulls more amps????
stilltippin863 Posted March 5, 2008 Author Report Posted March 5, 2008 can a amp that pull less amps over power a amp that pulls more amps???? for instance lets say the kicker zx 2500.1 and the hifonics bxi 2600 class d i belive the hifonics class d will pull less amps and over power the kicker amp am i correct???? b/c the kicker amp pulls alotttttt of power to push it's full watts and the hifonics don't pull alottttttttt of amps to push all of it's watts
IH8PunkRok Posted March 5, 2008 Report Posted March 5, 2008 (edited) dont understand the question edit: r u askin if an amp that uses less amperage can put out more watts than one that uses more amperage? Edited March 5, 2008 by IH8PunkRok -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
David Posted March 5, 2008 Report Posted March 5, 2008 for instance lets say the kicker zx 2500.1 and the hifonics bxi 2600 class d i belive the hifonics class d will pull less amps and over power the kicker amp am i correct???? b/c the kicker amp pulls alotttttt of power to push it's full watts and the hifonics don't pull alottttttttt of amps to push all of it's watts becuase the hifonics doesnt do all that its advertised todo.
BigPimpin91 Posted March 5, 2008 Report Posted March 5, 2008 He wants to know if an amplifier that draws less current than another amplifier can produce more wattage. Yes, in a way. Current is what drives your subs. You would want the high current amplifier over a non high current amplifier if they were the same rating. Example. Amp A=3000w R.M.S. Amp B =2000w R.M.S. Both wired to same ohm load. Ok say Amp A puts out the 2000w at 300v. That would leave 10 amps for current, about what your average Vacuum Cleaner pulls. Now Amp B does the 2000w at 50v. But the current is 40 amps. 4 Times as strong as Amp A. Current is how much electricity flows through a resistance. Voltage is how hard it is pushed. Veterans; feel free to correct. BigPimpin91's Banging Music
stilltippin863 Posted March 5, 2008 Author Report Posted March 5, 2008 becuase the hifonics doesnt do all that its advertised todo. well i heard and send they do push alot more then you think everyone puts them down b/c it is not one of the big names like kicker rockford fosgate or something like that but they are damnnnnnnnnn good amps but my buddy sells them at the shop all day long and we have yet to have someone come back and diss them and i truely belive the 2600 hifonics will out do the zx2500.1 and will also pull alottttttt less amps then the kicker zx2500.1 to run them
BigPimpin91 Posted March 5, 2008 Report Posted March 5, 2008 well i heard and send they do push alot more then you thinkeveryone puts them down b/c it is not one of the big names like kicker rockford fosgate or something like that but they are damnnnnnnnnn good amps but my buddy sells them at the shop all day long and we have yet to have someone come back and diss them and i truely belive the 2600 hifonics will out do the zx2500.1 and will also pull alottttttt less amps then the kicker zx2500.1 to run them Read above. BigPimpin91's Banging Music
IH8PunkRok Posted March 5, 2008 Report Posted March 5, 2008 well i heard and send they do push alot more then you thinkeveryone puts them down b/c it is not one of the big names like kicker rockford fosgate or something like that but they are damnnnnnnnnn good amps but my buddy sells them at the shop all day long and we have yet to have someone come back and diss them and i truely belive the 2600 hifonics will out do the zx2500.1 and will also pull alottttttt less amps then the kicker zx2500.1 to run them reason being the brutus amp are 1 ohm stable kicker are not therefore it takes more volts and amps to get the same amount of power at the same ohm load and brutus amps are over rated kicker is not -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
stilltippin863 Posted March 5, 2008 Author Report Posted March 5, 2008 reason being the brutus amp are 1 ohm stablekicker are not therefore it takes more volts and amps to get the same amount of power at the same ohm load and brutus amps are over rated kicker is not Now Why Do You Say Brutus Are Over Rated And Kicker Is Not Kicker Is Over Rated But Not alotttttt kicker you got to have like 4 batterys and 2 alternator to push it to it full power brutus you need like 2 batts and you will push it to it's max brutus does what is says
David Posted March 5, 2008 Report Posted March 5, 2008 I used to run the brutus amps, great entry level amps, they do not make rated power, that kicker amp does more than rated power all day long.
