Ok I just picked up one of these to replace the Explorer my son rolled recently. I will be moving my system over to it this winter/spring. I have a pair of Sundown zv3 18's and a DD m4 amp for low end. The front stage will consist of a pair of RF Power 5.25 coaxials and Dayton 8inch mid-bass ran off a RF Punch 400a4 the head unit is a Clarion CX 501. I also have a pair of grp 31 135ah Deka unigy batts and a optima yellow top for under the hood. I got lucky and nothing was ruined in the rollover most importantly my son and wife were unharmed.
Ok the plan is to run the z's in a 10.2-10.5 cuft box with either a rear firing swap able octoport(spl and daily) or a drivers side firing slot port with a port reducer for daily. Since I have never worked with a Volvo before I am in need of some info. First off the vehicle peak frequency so I have an idea where I want to tune for my burps. Will tune to 32-34hz for daily listening. Also if anyone has worked with these car before any tips on running the wires and such and any trouble I may run into while doing this project. Thanks guys.
Here is a pic of Matilda.
Clarion CX-501 HU
Rockford Fosgate Punch 400-A4 on
Rockford Fosgate T152 5.25 in center console and
Rockford Fosgate T1682 in front factory
Rockford Fosgate T2500-1BDCP on subs
6 12inch RF HX2's in 13.4 cuft. tuned to 30 with port in 47 with it out
240 Amp American Armature Alt
100AH C&D in back Optima Yellow top up front
I never did a install on one but I did work for Volvo for almost ten years. Alt wire should not be a issue since I believe you have a non turbo model.
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
Yeah it's the non turbo am going to do the big 3 don't know if I will get a bigger alt or not might be hard to find or expensive.
Clarion CX-501 HU
My tip for the volvo since I had a 98' s70, which has the same structure and engine as your 850
- The strongest grounding point on the vehicle is the aluminum sub frame, when you do the big 3, make sure the frame grounds are there
- You can fit a double din where the stock radio is, you just need to make a spacer to put underneath the radio to hold it in
- Make sure to deaden the roof since the wagon's roofs will flex like crazy
- Mike Singer makes the biggest alt for those engines, which ranges from 220 to 280 amps
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Thanks man already got the double din in the dash was the easiest factory radio to remove I have ever seen.
Clarion CX-501 HU
  • Who's Online   0 Members, 0 Anonymous, 2214 Guests (See full list)
