Av reciever help
So i have every thing hooked up but the subwoofer the back of my unit subwoofer out is a rca connection and my sub is a speaker wire connection
I tryed cutting an rca and adding speaker wire its not working any help or tips would be great this is the unis i have
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v673_black_u/?mode=model
2015 F-150 Platnuim
On your reciever the rca is a preout that needs to go to powered sub or a sub amplifier.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
Jam away!!!
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
2-5.25 Satori Mids
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
  • 3 weeks later...
I had that problem awhile back. I ended up using the preout from the reciever and running that to an amplifier on a 15v dc power supply. Works great and pisses off the neighbors. I can help you with your setup if you need, ive got a home stereo system as well
if your sub is amplified it may just be high level inputs? if so just connect it to the front left and right and adjust the crossover to desired cut-off.
  • Who's Online   1 Member, 0 Anonymous, 546 Guests (See full list)
