Tarball Posted December 12, 2013 Report Share Posted December 12, 2013 Here is some feedback I found on someone using blondewood - though I have never used it myself. for the first project i used 3/4 inch blondewood at work to build a high front extension to a secretaries desk . it was painted and had a top shelf of solid oak.#1 it smelled VERY bad when cutting.#2 when sanded it fuzzed up. ( we could not get that to go away)#3 it really sucked up the primer.#4 the thickness was not consistent.#5 and many voidsit looked ok but we should have used birch ply.2-3 weeks later i tried it again on angled locker top shelves at work. 4 sheets from another stack and found the same 5 things . i don't know how it would take stain. 4 15s in a wall - I would use double Baltic birch - not the home depot/lowes stuff either. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db Link to comment Share on other sites More sharing options...
Tarball Posted December 12, 2013 Report Share Posted December 12, 2013 http://www.wurthwoodgroup.com/Baltic-Birch-Plywood-34-Import-P78293.aspx something like that CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db Link to comment Share on other sites More sharing options...
