2 or 3 battery's better?
I used the power calculator and they recommend 3x khc2400 (7200 total) but for around the same price should I go with 2x khc3800 (7600 total)?
If it matters I'm gonna be using 2x 2500 rms kicker zx amps and a 1500 kicker zx.
(typo on the topic batteries) :BART:
either will work, but i hope you have a high output alternator in the 250-300a range. because you need more than just batteries, takes power to make power. I personally would do 4 of the 2400's, or 3 of the 3800's with a +250a alternator.
So would the bigger total / less batteries be better? Might even do xs power d7500 if thats the case.. and maybe a smaller battery as a backup?
I agree with chevy boy. A HO is a definite, what vehicle? Big 3? What wire? What subs? Multiple things need to be considered. If you are getting 3-4 batts then the biggest alt you can fit is my opinion. Thats alot of power and multiple decent sized amps will draw alot of power.
05 Escape
2 Ascendant Audiio Mayhem 15s dual 1
Populus Audio 6500 (the only one around )
1/0 SHCA OFC
XS 3400 under the Hood
XS 3100s in the rear X2
Pioneer 80 Prs
Pac
Prv mids and highs
2 8s per door 1 tweet
320 amp mechman, big 3, monster 400 powerflex 1/0, 2x 15" stroker pros, 4x hifonics tritons.
what batt under the hood?
05 Escape
1/0 SHCA OFC
Pioneer 80 Prs
Pac
Prv mids and highs
with a mechman 320, you can get away with what you posted originally. See what your voltage is, then if you need more, just add an additional of a matching series.
edit: biggest one you can fit up front, and then either 3 2400's or 2 3800's and go from there.
My question may have been lost in translation.. Would it be better to use 3x 2400 or 2x3800 and then as a side note (if less is better) maybe I could just use a xs power 7500?
Would I get too much of a voltage drop if I just put one 7500 in the trunk and nothing up front?
yea, it kinda did. I think you will see similar results with either set up [referring to 3800s vs. 2400s], and less is never better when it comes to electrical. i would personally think you would have better results out the the 3 2400s though.
  • Who's Online   0 Members, 0 Anonymous, 3374 Guests (See full list)
